Results 1 to 12 of 12
    Registered Member Two Rings
    Nov 03 2008
    Layton, UT
    A different exhaust type question
    I was wondering if anyone has replaced their oem mufflers with larger oem mufflers with 2.5" or 3" inlets and outlets? I'm thinking about making a 2.5" turboback with high flow cat and have it Y off into 2.5" or 3" oem mufflers.
    Anyone else try anything like it? What did it sound like? Performance gains? TIA!
    Jun 30 2007
    Raleigh, NC
    Re: A different exhaust type question
    nobody has done it... because audi doesn't offer our muffler with a 2.5 or 3" inlet/outlet...
    that's what aftermarket mufflers are for.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Nov 03 2008
    Layton, UT
    what about different manufactures oem type mufflers. I'm just trying to get more exhaust volume out of the engine with the least amount of noise possible.
    Veteran Member Four Rings durfA4's Avatar
    Jan 01 2006
    2012 A7 Stage 2, 2014 Q5 3.0T SLine, 2001 Laser Red S4
    Boston
    you can look into b6 s4 exhaust it will fit the back half. thats gonna be your best bet, i dunno the the diameter of the piping
    2012 A7 3.0t EPL Stage 2
    2014 Q5 3.0t
    2001 S4 STUKLR tuned
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Most people get Magnaflow mufflers for custom catback exhaust sytems they off a few different types with varying sounds levels.
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Believe me when I tell you, the mufflers constitute one of the highest exhaust restrictions on our cars Period.
    You can save the factory straw sized piping if you want. Just make sure you DO purchase a Magnaflow STREET muffler to replace the factory muffler.
    You will not get any performance out of the factory mufflers. It's a guarantee.
    Good luck
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    would hacking off the stock ones for straight pipes do for performance
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
    Nov 03 2008
    Layton, UT
    If I did a 2.5" downpipe that split into a dual 3" piping going into a factory style 3" inlet / 3" outlet exhaust still flow good since there will be about 6" of volume going through two mufflers?
    Jun 11 2005
    It will definitely open up your acceleration a lot more. And It would also give you some more top end. you will pull to 120-130 mph without feeling a thing. I promise you that much. Stock mufflers are extremely restrictive. It's not even a question
    Quote Originally Posted by 05A$SE View Post
    2003 1.8T
    Jun 11 2005
    I think you got it backwards here.
    You want a 3" Test pipe, to a 3" downpipe, to a 2.5" split pipe.
    Going the other way will give you minimal gains, MINIMAL while increase the noise to unbearable levels.
    Quote Originally Posted by 1_ate_t View Post
    2003 1.8T
    Feb 12 2008
    on a k03 wouldnt 2.5 to 2.25 be better then 3 all the way to dual 2.5? its not about how open it is if im correct. back pressure is bad however velocity is the main focus. having a system that is to free flow will have less velocity then one that has optimal pressure with smaller piping. Thats pretty much what ive learned thats why i was wondering about the mufflers but now that i think about it there is already enough velocity from the stock piping being as small as it is. no its not optimal but it is good enough on stock turbo. looks like im going with ebay straight through mufflers!
    Jun 11 2005
    Yes, 2.5 - 2.25 would be perfect. But with 2.5 i'd probably just keep it 2.5 all the way back. No sense in redoing the piping again if you ever want to go with a k04 or a BT for more power. Having 2.5 all the way through will allow you the versatility later on that will save massive time and headache.
    Picture, BT install, then Valve cover gasket goes, Maf Goes, sparks all go, timing belt goes, the list goes on....
    of stuff that you will have to regularly maintenance and keep up.
    wouldn't you want your exhaust to be the least of your worries?
    Just set it and you're DONE.
    I should know. I've gone through over 10 exhaust setups in 6 years. This doesn't include all the small adjustments and pipe diameter changes in between. I'm talking 10+ FULL Exhaust setups.
    2003 1.8T
