Originally Posted by
mxrz
If he would make the effort to change his existing tires, studded ones, like General's Altimax Arctic (US version of Gislaved Nordfrost 3) for example, would be even better than these.
I take it you have used these tires before?
Studded tires have their drawback when it it's not snowing and the road is dry. One and the big one is noise; second, it does limit your speeds a bit; and third, studs tend to fall out and as they wear, they lose their effectiveness. Since on the Green Diamonds, the carbide chunks are distributed throughout the entire depth of the thread, you maintain its capability throughout its life
Having studs on the shoulder area only isn't as good as having the traction aid across the entire tread-- good luck finding those (such as Menard tires).
I'd be running them on my current car, but they don't have the size I need (215/55r16) and the max cold pressure is the tire pressure I ran for my car (35 psi with the 205/55r16).
...though one time they did sell 215/55r16 Inari snow tires that looks like it can accept studs
There are drawbacks of Green Diamond tires. Not everyone is particularly a fan of remolds/retreads, thanks to the retreads that scatter the highways from truckers. Not everyone is big on Michelin bases either. It takes about 1000 miles for the tires to break-in, for the carbide chunks to appear...and for me, the max cold pressure is at 35 psi. If they made it in the specs I need... I'd be running them instead of Nokian Hakkapeliitta RSI.
