Results 1 to 25 of 25
    Senior Member Two Rings BryMFL's Avatar
    Apr 20 2007
    '02 Audi 1.8T Quattro
    Winter Haven, FL
    Exhaust and intake valves
    What is the difference in the TRW and Osvat exhaust/intake valves? I noticed the exhaust TRW valves have a sodium filler.
    Is paying 4x more per valve worth it?
    "BryMFL"
    Bryan Meeks
    "Quattro- It's like having your very own roller coaster ride!"
    Feb 17 2005
    Sarasota, FL
    Re: Exhaust and intake valves
    Are you talking about OEM replacements? Why not upgrade with Supertech if you want to stay cheaper or Ferrea?
    Apr 20 2007
    Winter Haven, FL
    Quote Originally Posted by A4ringedONE8T View Post
    If there are upgrades available then I'm all in(As long as they are within price of the oem)
    "BryMFL"
    Bryan Meeks
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    The Supertech components aren't that expensive.
    About $1000 for all the valves, springs and retainers.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Why do you need new valves? Did you really bend them? Did you update your other thread? I should go check...
    OEM ones are too expensive and weaker than aftermarket (like Shawn and Winston have stated before me)
    -Doug
    Apr 20 2007
    Winter Haven, FL
    I went through and checked the compression on all 4 cylinders and got nothing. I havn't takenthe head off yet that will be tomorrow once I track down the tool to remove the bolts with.
    Anyone care to let me know what type of bit is used to remove the head bolts? I think it may be a triple square?
    "BryMFL"
    Bryan Meeks
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by BryMFL View Post
    6point Poly Drive
    http://www.germanautoparts.com/Tools...and+valvetrain
    -Doug
    Apr 20 2007
    Winter Haven, FL
    Is this a local pick up kind of thing or order?
    "BryMFL"
    Bryan Meeks
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Depends on the stores local to you. Not sure if Napa carries them...
    I bought mine from that vendor. They are in southern NY so I order on a Wed morning and it shows up at my doorstep on Thursday since I'm one state over.
    -Doug
    Veteran Member Four Rings Redgoat's Avatar
    Sep 16 2005
    snap-on carries the tool
    -Karl
    NWQuattro - Northwest Audi Club
    USP CLUB MEMBER #8
    BetaAlphaTau member #10
    Feb 17 2005
    Sarasota, FL
    Did you try pulling the dipstick out with the car running? Any excessive positive pressure coming out? What were compression test and leakdown test results?
    Apr 20 2007
    Winter Haven, FL
    Well I wish I could say the car is running, but I will check the dipstick slot for pressure. The compression test showed 0 all the way across. Is that normal? and don't know what a leak down test is
    "BryMFL"
    Bryan Meeks
    Oct 29 2005
    10speed
    San Francisco, CA
    no thats not normal... doesn't sound good... The car just doesn't start at all your saying?
    - Clint
    Feb 17 2005
    Sarasota, FL
    Are you doing all the work yourself? Borrow a boroscope from someone and take a look at the top of the cylinders
    Apr 20 2007
    Winter Haven, FL
    Only thing I can think of is I have the valve cover removed to do the test and didn't build pressure that way. I wouldn't think that would be necessary though cause the pistons are sealed off on their own?.?.?.?.
    "BryMFL"
    Bryan Meeks
    Feb 17 2005
    Sarasota, FL
    valve cover off will not affect a compression test, might make a mess though. Very rarely do you get 0's on all 4 cylinders, are you sure you had a proper seal in the plug hole for the guage? Did your timing belt break?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Read this: http://audizine.com/forum/showthread...69#post3110069
    -Doug
    Apr 20 2007
    Winter Haven, FL
    Well either way I'm going to the store to pick up the socket drive to take off the head so I will get to the literal bottom of this. My fiance held her hand over one of the holes and barely got any compression, but I may have someone check by hand all the rest incase the tester doesn't work properly
    "BryMFL"
    Bryan Meeks
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Bryan,
    Yes, it is safe to say at this point that you should pull the head to do a visual on the valves. Sorry it has to come to this but another method is to pull the intake and/or exhaust manifold off to look down the ports. However, if you go that far you might as well just pull the head.
    -Doug
    Jan 25 2006
    A4 2.0T
    MD
    Car won't run with 'no' compression.
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by Don Supreme View Post
    Im aware of that, but the "hand over the hole" test doesnt qualify as respresenting a zero compression motor, and rarely does that happen (have all 0's) unless the motor is completely F'd in which I would hope you would know, not be guessing
    Apr 20 2007
    Winter Haven, FL
    Well it took me all afternoon but I just finally got the head off and the way it looks is ALL the exhaust valves are open and a few of the intake. Here are some pics of the valves and cylinder heads(is all the black build up normal?
    "BryMFL"
    Bryan Meeks
    Jan 25 2006
    A4 2.0T
    MD
    Center intake valve is fuxored....
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    All I see are red x's
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 17 2005
    Sarasota, FL
    Pics no worky
