Results 1 to 6 of 6
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    How do I check resistance 02 sensors? (01')
    I have a multimeter and I tried to follow up this write-up.
    http://www.audiworld.com/tech/eng101.shtml
    But once I got to it, I noticed that my 02 sensor connectors are different.
    I am getting a P1114 and its saying my post cat 02 sensor has too high of value. Where would I conduct the resistance check?
    I have only a brown and black connector (which I believe the black one is the post sensor). The brown connector has 4 prongs although the black connector has 6 prongs
    here is an example of the B6 02 sensor, but ours is different.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jun 04 2007
    Austin/DFW, TX
    Re: How do I check resistance 02 sensors? (01')
    Tttt
    My 5-Speed Swap DIY
    - B6 USP
    Jun 04 2007
    Austin/DFW, TX
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings szinkuti's Avatar
    Oct 06 2008
    Allroad Truck aka Uber UTE
    Grand Prairie, Texas
    dude..just replace it....if you need any help with your car drop me line...im over in ft worth....
    Jun 04 2007
    Austin/DFW, TX
    I dunno man, shelling out $150 is a lot especially if I can check to see if its working right with a multimeter.
    You're that new tech thats on Ntag right?
    My 5-Speed Swap DIY
    - B6 USP
    Oct 06 2008
    yeah thats me....pm me your vin
