Results 1 to 7 of 7
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Car is shorted - question about starter
    so my car was dead as a doornail the other day, and after I jumped it it was running poorly - my battery light was flashing, but i was able to get home. I figured my battery was dead
    i went to jump the car, and it wouldnt take a jump - in fact, there seemed to be a puff of smoke which came off the battery terminal connection.
    i brought the battery in, and they said it was dead/shorted, so they replaced it
    i now just put in the new battery, connected it up, and immediately noticed somethng was wrong - the cables started to heat up, etc.
    i disconnected it.
    The only thing I have touched recently is the starter to remove the trans. I only disconnected the bracket in the back of the starter, and nothing else.
    The bracket looks like this:
    so the first question... does this bracket serve as the ground for the starter? I'm wondering if the starter is somehow shorted
    how can i test the starter for a short
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Re: Car is shorted - question about starter
    anyone?
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    it looks like the cable from the starter that runs over the trans to the alternator is pinched between the trans and the engine... must have gotten caught when i re-installed the trans. I'm assuming that is the problem... this is so fucking annoying because I don't know how im going to free it up without disconnecting the whole trans again..
    I don't know how i fucked this up
    and even if I get it out, I'll probably have to replace it anyway
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    back up and running... harness was pinched between the trans and engine... im shocked i actually was able to get it home yesterday.. it must have been a small short which gradually got worse... check out this picture
    It looks worse that it was.. i pulled back the insulation and the wires weren't really damaged, they were just squished... I recovered them all really well with some electrical tape and I was back in buisness.
    pain in the ass was backing the trans off the engine and snaking out this harness... not the way I wanted to spend my day!
    Veteran Member Three Rings Hamotee's Avatar
    Oct 30 2005
    Other German Stuff
    Athens,Ga. Clemson,Sc
    Wow. Did you have to unhook the trans, or did you find another way to get it out?
    How to account for this massive success? Pure luck? Transcendental meditation? Machiavellian manipulation? Aerodynamics? High colonics? We haven't the slightest idea. -P.L. Newman
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Quote Originally Posted by Hamotee View Post
    unhooked the trans.... i just had to drop the rear support, the CV boot shield on the passenger side and the and the 6 or 7 bolts around the trans... it gave me enough slack to get a pry bar over there and push the trans back about a 1/2 inch... that was enough room to get the cable out
    Oct 30 2005
    Other German Stuff
    That sucks. Good call on the fix though.
