Results 1 to 8 of 8
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Help with axle bolts
    I'm in the process of removing the motor and I am having trouble getting the 6 bolts that hold each axle out. I may have stripped one already and I was wondering if anyone has any pointers to get them out?
    p.s. I'm going to punch that German son of a bitch who designed these cars with so little working room.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Help with axle bolts
    Are you using the correct triple square tool? Just make sure to blast all the gunk out and seat the bit well. The stripped ones, you're probably better off cutting the heads off of them now.
    08 S4- Stock SOLD
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    hmm didnt think they were that bad to get out, think its a 10mm tripple square. If you stripped the bolts they will be extremely hard to get out.
    Senior Member Two Rings Tokin's Avatar
    Nov 28 2007
    Audi S4 and Tiburon
    Daytona Beach
    Turn the axle between each bolt so you're always working with the bottom one. This method along with lots of extensions so the work is done outside the car. Easiest way.
    Senior Member Two Rings nocturnals4's Avatar
    Dec 10 2007
    '00 S4, '94 Z28
    P-dena,Maryland
    I got my triple square sockets from Autozone for $13 for 8,10,12,14mm you need the ten.
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    mine were very easy.. i did it under the car with no extensions whatsoever.. just the triple square from autozone and a socket/ratchet
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Veteran Member Four Rings HighDesertAudi's Avatar
    Mar 09 2005
    NorCal
    Yea you need the triple square, shouldn't be too hard to do. It helps if you rotate the axel so you get the best angle.
    Just wait till you take off the driveshaft, Now that is a PITA.
    Previous Audi's
    1999 Audi A4 1.8T Quattro 5spd Laser Red
    2000 Audi S4 6spd Nogaro
    1990 Coupe Quattro 5spd Lago Blue
    2000 Audi S4 6spd Laser Red
    2004 Audi S4 6spd Dolphin Gray
    2004 Audi A4 6spd Brilliant Black
    Jul 06 2007
    San Jose, CA
    Thanks for the help. I finally got those little bastards.
