    Dec 03 2005
    2 pedals 1FG
    connecticut
    Post B6 A4 1.8T REVO Stg2 Logs
    Met up with a fellow AZ B6er this morning to run some logs on his car now that I fixed my USB connection on my laptop.
    2004.5 B6 A4 sedan
    1.8T w/ 6spd
    REVO Stg2 with injectors
    ER Sport FMIC
    AWE test pipe and cat-back exhaust
    He got his car flashed at Waterfest earlier this summer. Coil Packs immediately died so the guys that flashed the car turned the timing advance back. Once home from WF he went and bought four new revision 'R' coil packs and things have been good since. However, the car did not feel peppy since the guys at WF turned back his timing advance.
    Well, today we figured out where the car currently was and turned the timing up incrementally via SPS3 until we were comfortable (keeping in mind its super cool outside [30F] and things will change come next summer). I decided to leave boost alone and just tweak timing advance.
    All logs are done in 3rd gear. We tried to get back-to-back logs while the highway was open. Reason being I wanted repeatability and also wanted to see how things were as the engine heated up.
    base log:
    Sunday Nov 30, 2008 9:00AM
    Timing looks like dogshit. Check out actual boost. Do K03s really taper off THAT much? I'm so used to seeing BT logs where boost holds up to redline. He insured me there are no boost leaks so I'm going off his word with that one.
    Timing 6, log 1
    Sunday Nov 30, 2008 9:05AM
    Timing 6, log 2
    Sunday Nov 30, 2008 9:17AM
    Timing 6, log 3
    Sunday Nov 30, 2008 9:18AM
    We are getting there. The car felt better.
    Timing 8, log 1
    Sunday Nov 30, 2008 9:24AM
    Timing 8, log 2
    Sunday Nov 30, 2008 9:25AM
    Timing 8, log 3
    Sunday Nov 30, 2008 9:26AM
    Getting better. Lets see what T9 does..
    Timing 9, log 1
    Sunday Nov 30, 2008 9:30AM
    Timing 9, log 2
    Sunday Nov 30, 2008 9:31AM
    Timing 9, log 3
    Sunday Nov 30, 2008 9:32AM
    Looking good!
    We settled on Timing 8 to be safe and knowing that next summer IATs will be much higher and he'll most likely get some timing pull. He was also happy and we noticed a big difference on T8 versus the dogshit the guys at WF left him with. Now he can really enjoy the money he spent on the flash.
    Can anyone confirm K03s really die that bad? I recall how my car used to feel 100% bone stock but I never logged my car nor had numbers to show for it. Guess I was a tad surprised watching his boost gauge peak at 20psi and then die off like a bunch of lemmings just jumped off a cliff.
    PS, thanks Martin for letting us borrow 'your' SPS3
    Enjoy!
    -Doug
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Re: B6 A4 1.8T REVO Stg2 Logs
    LOL, at least we know the SPS 3 works.
    Ok here's a log that I posted a while back and Doug helped me out with a pinging/spak plug issue.
    2004 1.8t quattro 6speed
    Forge DV w/green spring
    APR stage 1+ (91oct)
    TT225 (386cc) injectors
    stock cat
    stock IC
    Neuspeed cat back exhaust
    http://spreadsheets.google.com/pub?k...NQRIfXTEjwCCbg
    BTW, I think my MAF reading are kinda low...
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    lets bump this back up, i wanna see if other K03 stage 1+ users have same boost dying problem lol
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Yes a K03s boost will fall off. It is a tiny ass turbo so it gets a power spike and then looses all power at like 5000rpm and beyond.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Active Member Two Rings techniq's Avatar
    Nov 27 2007
    Raleigh, NC
    what data blocks do you guys want to see?
    [ 05 A4 1.8TQ :: APR Stg1+ :: SB Stg2 :: 3" Exhaust :: K&N :: FMIC :: Forge DV :: 18" Kyalami :: RS4 Sway :: STS Coils ]
