    Established Member Two Rings ecjr173's Avatar
    Aug 08 2008
    05 A4 1.8T S-Line
    Coolant Temp Sensor
    Will this work:
    http://www.autozone.com/R,1250712/ve...ductDetail.htm
    or
    http://shop.oreillyauto.com/ProductD...Number=TS85629
    Not sure why pricing is so different. But will one of these work.
    05 A4 1.8T S-Line
    Feb 17 2004
    Liberty Hill, TX
    Re: Coolant Temp Sensor
    either will work as a replacement for the sensor on the back side of the block, but not the one at the lower radiator hose
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    OEM part number is 059 919 501 A
    Retail is $26.38 average online is about $20
    Jul 31 2008
    lifted 96 Jeep Grnd Cherokee
    South of Boston
    The coolant temp sensor from autozone will work just fine. I used it to replace mine when I got a CEL. It just doesn't come with a new o-ring or clip. So check your old o-ring and don't break or drop the C-clip. good luck. hope you have small hands.
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    Yea, i second the AutoZone trip. mine cost $6 something. :P me and Matt up there compared OEM to it and its pretty much the Same, its actually more Green.
    Capt. Obvious: It's like fucking your cousin, just because you can doesn't mean you should.
