Results 1 to 10 of 10
    Registered Member Three Rings kovalevandrew's Avatar
    Oct 19 2008
    South Africa
    Best scanner to buy.
    I'm going to buy a scanner tomorrow. Which one would you guys recommend?
    Dec 05 2007
    Re: Best scanner to buy.
    VAG Com from Ross-Tech. All else is not worth it. If you have a Laptop, you can download the software, buy a VAG Com USB cable from ebay (yes, a $5 ebay cable), then purchase the lisence key from Ross-Tech. That is what I have. But I read that the best is to get the official Ross-Tech cable (when you purchase the cable, you get the software and lisence key. but it is ~$500).
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    you mean a police scanner or a "scanner" to be able to read whats wrong with the car?
    Oct 19 2008
    South Africa
    http://www.ross-tech.com/Merchant2/m...ry_Code=VAGCOM
    I'm thinking of ordering one of those.
    Oct 19 2008
    South Africa
    Quote Originally Posted by numer24 View Post
    Already got a number of those.
    Dec 05 2007
    My guesstimation price was waaayyyy off. But yeah, that one is the best to go with. Just make sure you order the corect cable. From what I have read, with those cables you will be permitted to do more logging, configurations, etc than if you buy an ebay cable and lisence key. Eventually down the road, I might also get that cable myself, as I have the older version of VAG Com (bought used from AZ member).
    Last edited by Seerlah; 11-30-2008 at 11:20 AM. Reason: added that I bought it used
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    I went the ebay route and I haven't been able to get my vagcom to work correctly. I'd get everything direct from rosstech if you have the cash.
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Oct 19 2008
    South Africa
    Quote Originally Posted by Kyle H View Post
    I'll gladly spend the cash on getting the right thing the first time.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Go with the one straight from rosstech then. It's not worth the headache to do it my way... plus, with that build you're planning you'll want to be able to datalog with no problems.
    because racecar.
    Oct 19 2008
    South Africa
    Already placed my order, should be here this week still.
