Results 1 to 3 of 3
    Veteran Member Four Rings A4orce84's Avatar
    Feb 12 2004
    Austin, Texas
    Answer Needed ASAP - Brake Pad Sensor (Front Brake Pads Question)
    Hey Guys,
    My buddy and I changed a wheel bearing on my A4 yesterday, and everything went fairly smoothly with the install.
    However, tonight my brake pad sensor light came on. During the wheel bearing repair, you are supposed to disconnect the brake sensor from the pad. I know when we were reconnecting everything when wrapping up, it seemed that the brake pad sensor wire was just sitting on the pad itself, without anything really holding it down. Note on the brake PAD, not the rotor or anything else.
    So my assumption is that the brake pad sensor wire came lose from the pad and that is what is throwing the brake pad indicator light.
    MY QUESTION - is then how is the actual brake pad sensor is supposed to be attached? If anyone could provide any detailed information or pictures, I would be appreciate it GREATLY!
    Thank you in advance for all your time and help everyone! =)
    --Asif
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: Answer Needed ASAP - Brake Pad Sensor (Front Brake Pads Question)
    the wires go inside of the brake pad so that when it wears, the wires would be disconnected by the friction of the rotor making the light go off.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Feb 12 2004
    Austin, Texas
    Is there any pics out there of how exactly it needs to be positioned zrowcool?
    Thanks for the quick reply BTW !
