Results 1 to 40 of 50
    Sep 20 2004
    2001 a4 quattro
    Sactown
    Chipped guys how much boost are you running?
    Whats up guys, i was under the impression that most chips were 1 bar 14.7 psi with the giac x chip being more, i think 1.3 bar. I have a dahlback chip on my 2000 and i think its a 1 bar chip and my gauge shows 12psi but thats because my piece of shit autometer gauge sits in vaccum when the car is off so im guessing im boosting around 1 bar. so i was wondering how much psi you guys were running and if you have increased your boost, how have you done it ? I have heard that MBC and EBC's screw up how the boost comes on, is this true? thanks guys \
    also how much boost do you guys loose when its say 55 degrees out?
    Nov 24 2008
    florida
    Re: Chipped guys how much boost are you running?
    i'm running 20ish lbs on the apr 93 using a mbc.. any more and i hit limp mode hard..
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    aeb with giac...ill spike at 17 with an n75h
    Dec 05 2007
    ~22psi max on CTapp tune. Only thing I changed is a Forge 007 dv.
    Sep 20 2004
    2001 a4 quattro
    Sactown
    Quote Originally Posted by blacktransam View Post
    can you really just raise the boost 5 psi with the MBC without actually adding more fuel to the tune?
    Sep 12 2007
    2001 Audi A4
    I held 22psi with Dahlback on the N75k. No, mbc.
    B5A4 Disco Potato!
    Sep 20 2004
    2001 a4 quattro
    Sactown
    Quote Originally Posted by 01_A4_Black View Post
    i think the dahlback software for the 2001's are 1.3 bar, but does the type of N75 valve effect boost that greatly? and what is the stock N75 valve ?
    Active Member Three Rings turboquattro068's Avatar
    Mar 20 2005
    99.5 Audi A4, 99 Honda CBRf4
    Upstate, new york
    held?
    Veteran Member Three Rings b5andm3's Avatar
    Aug 22 2008
    Central Maryland
    Quote Originally Posted by a4rings View Post
    I want to know the answer to this as well. My logical thinking says this is a VERY bad idea unless APR tunes very rich
    2000.5 A4Q - 2871r / 1.9L Stroked / IE Rods / JE Pistons / 3.5" TBE Exhaust / Forge MBC / 630cc Injectors / Walbro 255lph Fuel Pump / VR6 MAF / Unitronic Tune / CM FX600 / ECS N75 Race Valve / ECS 9lb Alum Flywheel / Forge TIP / Forge DV / ARP Head Studs / BBS LMs / RS4 Front Bumper / Hagus Mirrors / Brembo BBK / RS4 Shift Knob / JL Audio Speakers, Subwoofer & Amplifier / Clarion NX409 / HR Race Springs / Evolution Racewerks FMIC
    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    I was holding around 18-19psi with my old GIAC chip. Stock AEB
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    i have speedtunings 1.1 bar tune now.. 1st and 2nd gear i hold 10, 3rd i hold 16, 4th is 16-17, and 5th is 19 psi.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    i hold 21 psi with giac on my atw
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Established Member Two Rings Longfist86's Avatar
    Nov 01 2008
    08 MkV GTI, 09 Jetta
    Dade county
    20- 21psi revo stage deuce
    GERMAN CAR DEPOT
    2130 Fillmore St.
    Hollywood, FL 33020
    954-921-1515
    www.GermanCarDepot.com is your dealer alternative.
    Veteran Member Four Rings FLACO X3's Avatar
    Jun 05 2008
    B5S4, B7A4
    Thornton & Elbert County, CO
    22 psi with Eurodyne
    2000 S4
    2008 A4 2.0TQ
    Veteran Member Four Rings AudiSport12's Avatar
    Feb 17 2006
    Coastal Georgia
    22 with APR before the FMIC. 19-20 after
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2001 B5 1.8TQM F21L - Sold
    2000 B5 1.8TQM - RIP
    2000 C5 4.2Q - Sold
    1997 B5 1.8TQ - Sold
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    Quote Originally Posted by b5andm3 View Post
    The maf should be metering the incoming air so it should be safe, you can get an overboost code and go into limp mode though. Small gains in horsepower usually below 50 chp can be compesated for by the maf. 5 psi on a ko3 isn't much difference in hp but sometimes is enough to get the overboost code, some people have gotten an overboost code from the n75 race valve.
    Veteran Member Four Rings Jibberific's Avatar
    May 21 2008
    az
    I am only hitting 15 in 5th gear with GIAC and N75H. I think something's wrong.
    {99.5 Avant}
    Dec 05 2007
    What about the other gears? Boost leak test?
    May 21 2008
    az
    like 10 in 3rd, 12 in 4th.. Did a boost leak test, only heard the oil bubbling. The vacuum lines are all intact and it can't be my DV.
    It seems like my throttle cable has a lot of slack in it though... i am thinking my throttle plate might not be opening all the way at WOT.. Need to meet up with somebody who has VAG COM
    {99.5 Avant}
    Sep 12 2007
    2001 Audi A4
    Quote Originally Posted by turboquattro068 View Post
    held?
    Yea, would spike ~24psi.
    B5A4 Disco Potato!
    May 04 2008
    Columbia, SC
    Quote Originally Posted by Jibberific View Post
    What size piping on the FMIC?
    May 21 2008
    az
    only 2 inches, it's a racetec
    {99.5 Avant}
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    x2
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    99' AEB with APR91:
    Hold 16ish in 1st and 2nd and 3,4,5th gears 17-18ish with N75Race combined with a Hyperboost valve.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    when I had my Ko3 on I had a MBC set to what I thought to be about 18psi on UNI software but never saw that because of boost leaks and then once i fixed my boost leak it hit about 20 and then the next day my turbo took a dump on me.
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    were you tuned for the n75k?
    i also have a dahlback chip on my 01' - I usually see around 21psi.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    18psi spike and would taper to 6-7psi at redline. Added in a MBC I spike 18, hold 16-17 (depending on heat soak, ambient temps, etc) and taper to 10psi at redline.
    Unitronic Stage 1+, Forge 007, turbo back exhaust, ... Modded airbox? Does that count for anything?
    Sep 12 2007
    2001 Audi A4
    Quote Originally Posted by tdn View Post
    Yes, I had it tuned for N75k, intake, and larger dp/exhaust.
    B5A4 Disco Potato!
    Registered Member Two Rings 4BLKRNGS's Avatar
    Oct 22 2008
    Monrovia, MD
    98 AEB GIAC 91 with ECS tuning N75 Race Valve and Godspeed front mount -18psi
    Senior Member Two Rings EuRoSp1c's Avatar
    Nov 04 2008
    Jersey
    eurodyne stage 1... autobahn tip, n75 race, 007 dv, bkr7e plugs, 1st 2nd 3rd spike 21 hold 17 or 18, 4th and 5th spike 21 and hold it. i love this flash just aggresive enough stay dead even with r32 that runs 14.4 until 5th. fmic and exhaust this week nd mbc well see how that goes.
    2000 atw by the way
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    For all of those that are 00+ I think yall should run the diode mod to prevent limp?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings J Ozzie's Avatar
    Jun 06 2008
    Port Moody, Canada
    i have a 2001 dont think its chipped with a testpipe, running 16 psi some times in 3rd gear. and holds other times its 14 then the odd days it will be bout 10psi
    2014 Audi Q5 TDI - Brilliant Black | LED Fogs | VCDS Mods | LED Interior swap |
    R.I.P... (wrecked)2005 Audi A4 1.8TQM 6Speed
    R.I.P..2001 Audi a4 1.8TQM (casa white no sunroof)
    Vancouver Audi Club.ca
    where's our resident intoxicated lobster Canadian - Thomas
    Sep 20 2004
    2001 a4 quattro
    Sactown
    when you do a pressure test how much do you guys fill the system? at 10 psi on my gauge the TIP is ballooning to the point that it makes me feel like its going to rip. do you guys continue pumping air in there or what?
    And so if i just change my N75 to a more agressive one, will i get more boost? or do i need to get a MBC?
    Veteran Member Three Rings Jc61990's Avatar
    Aug 22 2008
    2002 Audi TT 1.8TQm
    Long Island, NY
    i got SpeedTuning 1.3bar chip. software is screwed up but when it was running i was moving, spiking 19 holding 17. im getting it knocked down to 1.1 cause the 1.3 needs work. and i can throw an mbc on and easily get to 22+
    JC | 2002 Denim Blue TT Coupe 1.8TQm
    Past: 1999.5 Brilliant Black A4 1.8TQ
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    when i was k03 i ran 24psi with GIAC and MBC, held 17 - 18 psi till 6200rpm
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Senior Member Three Rings UCFQuattroguy's Avatar
    Jul 05 2005
    '01 Audi A4 TMQ
    Orlando,FL
    IIRC from last time I logged...I'm running a peak of 17-18psi (depending on temp). Tapers down to 9-10psi at 6500...but anyone on K03 has no business winding it out that far (when I auto-x I"m shifting at 5750 or there abouts). I'm running 50/50 water/meth injection on APR's 100oct tune....scoots pretty good for what it is (k03+quattro)
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    ive been watching these posts & obviously there alot for people with KO3's & the boost levels seems are high. wish i had a MBC with my KO3. not to thred jack but what are the average boost for people with KO4.......TIA
    Sean
    The New
    B7---GIAC--BBS--DDM--JHM+S4Exhaust--StaSIS SS--034--AudiUP--USP--RedEBC--IE--DrakesVC#12--B7S4 Brakes--StopTech--GFB DV+--
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
    Dec 05 2007
    If I am not mistaken, I think the max boost levels for a k04-15 is 25 psi (safe). And even though I peak ~22psi, I don't go around driving WOT all day, so I usually hit ~15psi max when I feel like moving. But when I feel like driving spirited, I enjoy the extra boost. I just wish at times I had at least a GT28r.
    Oct 08 2007
    Jersey City
    do you use a MBC to hit 22psi?
    Sean
    The New
    The Old
    Dec 05 2007
    Nope. Just a Forge 007 dv. So, no need for an mbc. People get MBCs usually to add more boost (which I do not need) or to even out surging issues (which I also do not encounter snce I have a Forge dv with the yellow spring). I would conjectire a person whom has a k03 vs a k03s to boost a little less, but this is just a conjecture.
