    Nov 29 2008
    texas
    Multiple CEL Codes...Need help
    The car is a 04 a4 1.8t fwd sitting at 85k.......
    PO171 bank 1 lean
    P0300 multiple misfire
    P0301
    P0302
    P0303
    Po304
    I think that the P0171 came on right before it started to misfire. But it started to feel like when you hit the gas it didn't want to move sometimes.
    I can't find any vac leaks. I clean the MAF. Changed the plugs. Any ideas on what's going on? I'm starting to think that it could be a fuel issue. Maybe a clogged filter but if I get on it it doesn't bog down. You can really feel the missing at idle and when driving it kinda like it semi-jerk just for a split second every once and a while. Please I need some help
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Multiple CEL Codes...Need help
    Most likley a bad MAF or vacuum leak. The 171 code is the cause of the misfires.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Nov 29 2008
    texas
    The only noise I hear sounds like its coming from the intake. I can't find any leaks there. Does the air moving into the intake sound kinda like a leak? What is the normal MAF reading?
    Nov 29 2008
    texas
    bump
    Nov 29 2008
    texas
    Thanks for the quick reply dirtybrd. Anyone else have an advice for me.
