Results 1 to 16 of 16
    Well the weekend just keeps getting worse...
    Yesterday i was on a cruise with a couple of buddies. A piece of concrete was laying in the middle of the road. By the time i saw it come out from under my buddys car it was too late. Hit the tire pretty hard and this is the result...
    Since i got a flat on the same place a week prior at a rally i had to have the car flatbedded back to my house. I give Audi Roadside an A++++++ for the customer support...
    I used audi's jack today to lift the car up and take the wheel off. During all of this the jack failed and my car almost ended up on the floor. Luckily i had another jack (didnt use this i nthe first place because its took high to get under my lowered car) right there to get it back up. The stock jack put a nice little hole through the lower side skirt of my car. It also put a nice nick in the rear door blade.
    Is there any chance that Audi will cover the repairs on the skirt and blade due to the jack failure? There was no negligence on our part, the jack was positioned properly on a flat concrete garage floor.
    And thats my weekend so far...
    Re: Well the weekend just keeps getting worse...
    Damn, dude. Sorry to hear about it. If I were you I'd probably get out a bottle of Jack and go to town.
    6MT | Alcantara | 35% Tints
    Feb 26 2008
    b7s4
    Quote Originally Posted by joeycuccaro View Post
    After looking at the tire i noticed grease all in the tire. Looks like a rear wheel bearing went. Going to take it to Audi to fix under the CPO.
    sorry to hear that, also good luck getting the wheel bearing replaced under CPO with a modified suspension
    audi will not warranty the ramifications of their jack either
    Veteran Member Four Rings CruzS4's Avatar
    Mar 01 2007
    WK2
    Conshohocken/Sea Isle
    Quote Originally Posted by JB_ImolaS4 View Post
    ha. the cause and solution to all life's problems. i hear you on the shitty audi jack, mine failed on my old S4, nearly severing my hand, and f'ing up my side skirt as well. at that point my car was out of warranty so i didn't bother pursuing it. sorry to hear of your woes man
    '17 Ibis White B9 A4 quattro P+ S-Line
    After looking at the wheel and suspension it looks like its the axle or cv boot that caused the grease to spew everything instead of a wheel bearing...
    Registered Member Two Rings
    Jan 14 2008
    I had to change a tire on the side of the road due to a flat one time and I was very uncomfortable with the jack provided with the car. Its very flimsy looking and I can easily see how it would fail. I'm surprised they didnt provide a more sturdy jack due to the cars weight and price...
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    Sorry for your bad luck. I've used the stock jack 2 times now, and it's worked perfectly each time. I think you first have to start any jack using operation by pretending that you are German, look at the ground, the type of the surface you are using, the angle of the surface, drink a litre of beer, eat a sausage, and then think about how you would perfectly put the jack in place before doing it.
    I've used it on concrete and on the side of the road in dirt without a hitch. I have to say it sure looks funky when in action and if you had it slightly off to an angle it will surely collapse.
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Dec 05 2006
    So. Cal.
    Mine nearly failed on my B6 S4 in my garage. It did however, put a gash on my side skirt. That jack is unusable.
    Senior Member Two Rings 05UltraSprt's Avatar
    09 Armada (4 Kids, gotta have it)
    Fort Myers, FL
    I have also been screwed by the fine engineering of the Audi jack. It was on my old USP, big gash in the side skirt. That thing is such a POS!
    Veteran Member Three Rings Audi05s4's Avatar
    Oct 17 2006
    Hockessin, DE
    i had the jack do the same to me
    daworldisyours.com/forum<----check it out!!!!
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    did they change the jack for the B7? I have a 2007 S4, and am wondering if I should throw that P.O.S. in the trash in favour of a better one?
    Quote Originally Posted by sakimano View Post
    do yourself a favor and junk that POS right now...
    invest the extra in a nice low profile jack
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    yo...email me. i might be able to get you a new wheel/tire (OEM) for free.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Established Member Two Rings bjs's Avatar
    Mar 22 2008
    Doylestown, PA
    About a month ago my jack on my b5 s4 failed me while I was changing a flat and my car went right down onto the rotor about. Messed up my dust shield which doesn't really work anyways lol. At least the jack was stuck under it's skirt when it went down so it didn't hit the rotor too hard.
    Current: 2015 Black C7 S6
    Sold: 2011 Ford F150 Raptor
    2009 C63 AMG
    2009 E92 M3
    2008 B7 RS4
    2002 E39 M5
    2000 B5 S4
    2001 TT
    1990 Audi 80
    Established Member Two Rings toneloc's Avatar
    Jul 08 2008
    none
    SO/CAL
    badluck!!! well let me vent alittle... this all in 2 weeks time.. nothing this week tho.. got a parking tic for no front plate parked in front of house.. same day got a rear flat @ school while picking bro..lucky my audi jack failed when i got the car so i had a better jack.."O when jack failed my whole front was on the cement with no front wheels on" very nice!!! last tue... some1 hit n run my rear driver side.. put a hole in my rear bumper..dented and scratched my quarter panel... im gonna feel much better when this yr is over!!
    deval splitter.from EUROGEAR.installed by AUTOWERKS
    HRE 441R 19x8.5x35x245..thank STEVEN.
    vogtland GT coilovers.STARTUPRACING.. installed by CHARLIE
    RS4 blk optic grill n plates.. TM TUNING
    RS4 Bumper..EUROGEAR..painted installed by AUTOWERKS
    Well it didnt turn out to be as bad as it was. The CV boot was not cracked or broken. The Axle was not busted either. We believe the impact was so hard on the CV boot that it let all of that grease out. A good friend of mine hooked me up with a few tires so i am set with them. Just need to pick up another spare wheel now and ill be good.
    Huge Huge props to Sami at Elite Motors. As always he took care of me with the best service out there. If any of you are from the tri-state and you have a problem with your car please give him a call. www.elitemotorsnj.com
