Originally Posted by
Swanky
normal it's the differential
Huh, the diff shouldn't make any noises at all!
What the OP may be experienceing is the ABS/ESP system carrying out a self-calibration - though it should be barely noticeable on the latest ESP 8.0, though was slightly more noticieable on the earlier ESP 5.7.
It should only do this once though (after the initial engine start), and shouldn't do it again after the intital self-test. If it does it more than once, it is an indication that something isn't quite right with the calibration tests - could be dirt/crud on one of the wheel speed sensors, or something more serious. However, if it is anything permanent, then the red warning light in the instrument panel will illuminate.
