    Senior Member Three Rings JK35's Avatar
    Apr 08 2008
    97 B5 TQM
    SW Florida
    intercooler selection
    I need to choose an intercooler setup for my 97 B5 TQM. I'm running a TIAL/Garrett GT3076R on a soon to be stroked 1.8/2.0 058a AEB Megasquirt II v3.0/74lbs/hr low-z injectors in batch fire setup off an externa board, and the COP ignition is fired sequentially off 4 BIP373 transistors. -Fueling is more than sufficient, and I am expecting mid to high 400's on pump.
    I'm torn between a high quality FMIC and a liquid to air setup
    Air to air would be a Garrett or Spearco core, liq. to air would probably be Bel.
    I'm also stuck on what size piping to run? the discharge is only 2" diameter, most IC's I'm looking at are 3", and I won't likely step up to my Q45 throttlebody until after the bottom end work (stroke) is done this Spring.
    2.5 to the IC and 3" to the throttlebody? anyone have any lnke to decent writeups on "selecting IC pipe sizes" ?
    Would surely be appreciated...
    I should receive a couple large boxes of schedule 10 and 16ga this next week... -I'll try to post some pics of the full V-band equal length tube header, 3" DP and straight exhaust system as it's being fitted and welded by next weekend.
    late
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: intercooler selection
    Not to be a dick, but this is the B6 forum. But since I'm here either of those cores are good, and 2.5'' is perfect.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Apr 08 2008
    97 B5 TQM
    SW Florida
    now how the --- did I do that? thanks, and excuse me
    Oct 29 2005
    10speed
    San Francisco, CA
    you'll never get high 400s on pump gas with a 30r... 2.5" both sides should be fine.
    - Clint
    Mar 21 2006
    Lakeland, FL.
    At the crank.
    I'm back bitches!
