Results 1 to 7 of 7
    Established Member Two Rings Stevet05A8L's Avatar
    Aug 16 2008
    2005 A8L 4.2
    Santa Monica
    06 A8L Shrudders at stops, any idea?
    Just yesterday I came to a stop and I can feel all of a sudden when fully stopped at a light the engine seemed to shudder and I can feel it lunging sporadically as if I'm having a misfire. Then the engine light came on, I don't have a OBD2 reader, does this sound like a coil pack went out? Oh! and it's an 05 not an 06
    Appreciate any thoughts
    Senior Member Three Rings TverRus69's Avatar
    Sep 02 2008
    98.5 2.8 A4 QM
    NYC, Penn State, Tver Russia
    Re: 06 A8L Shrudders at stops, any idea?
    could be the MAF going bad, but probably the coils. Check which cylinder is having the misfire (assuming it is one) and swap coils with another cylinder - see if the misfires changes to that one.
    Oct 09 2008
    Wish I had advice for you, when you find out the problem please let us know what it is.
    Aug 16 2008
    2005 A8L 4.2
    Santa Monica
    Brought it to the dealer (Still under original warrenty till July 2009) an it was a coil pack. They are changing all of them thank god! so should be good to go! I'll be picking it up today.
    Senior Member Two Rings DirtyJerzey's Avatar
    Feb 24 2008
    NJ-LA-TX
    Another coil pack bites the dust... I've been hearing a lot of coil packs going wrong lately:(
    Veteran Member Four Rings minira's Avatar
    Feb 13 2004
    Jurupa Valley
    glad you found that out. i had three go bad two days ago in my junker
    77 Porsche 911S
    13 RS5
    14 Porsche Panamera GTS
    16 Tundra PRO
    20 Sequoia PRO
    07 zx6r
    Jan 08 2008
    Harrisburg, PA
    Yeah unfortunatly that is a common issue with the D3's. I bought one at auction for a customer, made it home, went to pull it into the shop to do the emissions test and viola...coilpack died...had to spend another 2 days driving it (what a shame) to get thre readyness monitors to set after clearing the check engine light. But as was mentioned, read the code it should show you right away which cylinder the misfire is in and if its in other cylinders as well, it will show that cylinder as well as mulitiple engine misfire.
