Results 1 to 4 of 4
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    How To Remove Podi Wiring Harness???
    I plugged the wiring harness into the back of my stewart warner gauge, and because the LED bulb sits loosely while plugged in, it popped out of place as soon as the harness snapped into place. how do i remove the plug without breaking the clips? ie. if you were to change out the red bulb to white how would you remove the plug?
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    May 24 2007
    Southern California
    Re: How To Remove Podi Wiring Harness???
    mine did that once. i think you just squeeze and pull back out. simple.
    Kyle
    2.0L Revo GTRS Eliminator
    Mar 27 2005
    The Cold North
    i just pulled slightly off center and the plug pops right out. Also if you pull/push the little brass bulb holders closer together the little bulb will stay in better.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Apr 25 2007
    MA
    good info, thanks guys. didn't want to remove the plug with outward force until i knew it was ok.
