Results 1 to 17 of 17
    Veteran Member Three Rings v1nyd's Avatar
    Jun 15 2008
    Long Island NY
    Turbo bracket allen bolt stripped...help?
    Got it out thanks guys!!
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Re: Turbo bracket allen bolt stripped...help?
    Pliers.
    Or maybe try to cut it down on two sides and then use a wrench to screw it out... otherwise cut it.
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    Jun 15 2008
    Long Island NY
    I tried getting pliers around it but the bracket won't let me get them on the bolt, I don't know what to use to cut it because its a tight fit in there
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    you can try and take the allen from the bracket to the block out.
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Jun 15 2008
    Long Island NY
    Quote Originally Posted by lowandslow4now View Post
    I was thinking that but I didn't know how to get to it, from the engine bay and under the car I couldn't see where the other end of the bracket is...do you know the best way to get to it? Thanks!
    981CGTS, Cayenne Turbo, '22 A4 Allroad
    Chicago 'burbs
    What I have done in the past was grind a little off the tip of the allen socket and tapped it into the allen to make sure it is well seated.
    Or Sears sells damaged bolt removers that may help.
    2014 A4Q Red w/ black optic black interior
    Jul 12 2008
    Cumming, GA
    I used a long t-handle from underneath. I couldnt get it because it was to tight but I had already gotten the turbo off
    Now 2001 B5 S4
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Those bolt-outs from craftsman are a life saver.
    Jun 15 2008
    Long Island NY
    I have those bolt out sockets however I used to get stripped lugs out in the past and I had to hammer them onto the lug to get them to catch the lug, I don't know how to get them on this tiny allen bolt good enough to break it loose
    Jun 15 2008
    Long Island NY
    oh and by the way I appreciate all these responses to my dilemma, thanks guys!
    Veteran Member Four Rings Quattro 4 Life's Avatar
    Feb 05 2008
    '64 Pontiac Catalina
    Kenmore
    yeah this bracket and screws are a royal pain. here are a few options:
    1) buy a 6mm allen head socket that you can get an extension on. this will allow you to get the bolt on the engine block off and possibly the bracket.
    2) take a sawzall and cut the damn thing
    3) grind the upper screw head all the way off until the bracket isn't connected to the turb anymore.
    I did all three in getting it off, in reverse order actually
    * Oh and definitely buy some PB blaster and soak the lower screw so you have a better chance at getting it off. the stuff does wonders
    2013 Phantom Black C7 S6 Stage 3 | 2007 Ibis White B7 A4 Avant 3.2QM Titanium - 1 of 2 | 2013 Glacier White Metallic 4L Q7 3.0 TDI
    Past: 2003 Brilliant Black C5 S6 Avant | 2011 Quartz Grey C6.5 A6 3.0T Prestige | 2000 Silver C5 A6 2.7TQM | 1999 Laser Red B5 A4 1.8TQM PC-16
    IG: tyscalzone
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Easy, if its accessible that is... Bang a torx socket in there
    If that doesn't work, you didn't round it out enough yet or you didn't bang it in hard enough
    Trust me
    Senior Member Three Rings JK35's Avatar
    Apr 08 2008
    97 B5 TQM
    SW Florida
    can you weld or are you close by someone that can weld something for you?
    I've stripped out more hex's and torx heads than you can shake a stick at... I generally cut off about an inch and a half-two inches of an allen key, weld it into the stripped head, put a socket on the hex "stub" and back it out while it is still red hot. GL
    Jun 15 2008
    Long Island NY
    Quote Originally Posted by Quattro 4 Life View Post
    Yes my can of PB Blaster is my best friend ha, I'm going to soak the bottom bolt of the bracket and try do the extension thing since I have no room to work with for the other options...I just still got to figure out a way to find that lower bolt, can I access it from underneath the car or above? and do I have to move anything out of the way? because I quickly tried to find it when this first happened and couldn't see it, but I wasn't trying hard enough I'll go check now. Thanks!
    Jun 15 2008
    Long Island NY
    Also...is this bracket necessary? Say if I cut it off or take it off the block and for some reason can't get it back on, it's it really worth replacing or struggling to put it back on....seems like it doesn't do much
    Oct 27 2007
    In the lab
    Torx....
    Feb 05 2008
    Kenmore
    no the bracket is not necessary, Harv over on vortex has run a K04 for a few years now and has had no problems without it.
    jack the car up and block it off, then access the bolt from underneath. you have to reach around a few AC lines, and the AC compressor it self
    Good luck!
    IG: tyscalzone
