Results 1 to 37 of 37
    Vivid Racing brings you A4 specific Audio Enhancements by Diamond Audio!
    Vivid Racing now sells packaged custom car audio kits for your A4/S4 vehicle. We have taken the difficulty in researching, reading, and assembling a car audio package to provide you with these solutions for your vehicle. We have provide complete turn key solutions from basic OEM replacement systems to high end full audio setups. Each package is specific for the vehicle listed. If you need a custom package or setup, contact us via PM for any questions.
    As an authorized distributor of Diamond Audio, Vivid Racing wants to take your tunes to the next level! Get the bump in your trunk you've been wanting!
    Diamond Audio Sound Enhancement Package 1 B6 A4/S4
    Want to improve the sound system in your Audi without spending huge dollars? Well Vivid Racing has partnered with Diamond Audio to introduce this Level 1 speaker package to directly replace your OEM door speakers with better quality, better sounding car audio components. This Level 1 kit features the Diamond Audio D3 6.5" component set for the front and rear speakers.
    Our new D3 speakers might be the starting point of our coaxial and component range, but they are anything but entry level. We start with the same high density proprietary composite ABS frame found in our D6 convertible systems, add a butyl rubber surround and a graphite injected polypropylene cone and you have the makings of a very good driver. Whether choosing a component or a coaxial system all D3 speakers utilize 1” aluminum dome tweeters. Our D3 component systems use an outboard 18dB high pass/ 12dB low pass crossover with our RAF (Rear Acoustic Fill) circuit so it is easy to add more speakers to your system. You won’t find a better combination of value and performance anywhere.
    Level 1 Kit Includes:
    Front D353 - 6.5" Component Set
    Rear D353 - 6.5" Component Set
    $339 Shipped
    Diamond Audio Sound Enhancement Package 2 B6 A4/S4
    Don't want the cheap products but don't want to spend a fortune on a car audio upgrade? Well Vivid Racing has partnered with Diamond Audio to introduce this Level 2 Sound Enhancement package to directly replace your OEM door speakers with better quality, better sounding car audio components and add a 10" subwoofer for bass! This Level 2 kit features the Diamond Audio D3 6.5" component set for the front and rear speakers. Next we add a 10" subwoofer with large rubber surrounds and a titanium finish. To power this package, we include for the front speakers a 300 watt D1 4 channel amplifier. The rear 12" subwoofer is powered by a D1 400 watt monoblock amplifier.
    The most dramatic improvement you will ever make to any audio system is by adding a subwoofer. D1 series 2 subwoofers make it easy. These new subwoofers have large roll rubber surrounds and larger motors for better power handling than competing models. They are available in either dual 2 ohm or 4 ohm versions. They work equally well in small sealed or medium vented enclosures. They sound great. And best of all they are affordable.
    The D1 amplifiers offer just the right mix of features and power and are a perfect match for our D1 subwoofers. D1 amplifiers feature 12dB per octave high and low pass crossovers and 6dB of bass boost. With both RCA and high level inputs it is easy to upgrade your factory system or build a great sounding all out show stopper.
    Level 2 Kit Includes:
    D110 10" Dual Voice Coil Subwoofer
    D1 300.4 - 300 Watt Four-Channel Amplifier
    D1 400.1 - 400 Watt Monoblock Amplifier
    Wiring, Hardware, Instructions to connect to a head unit is NOT Included.
    Professional installation recommended.
    $1069 Shipped
    Diamond Audio Sound Enhancement Package 3 B6 A4/S4
    If you want the best sound quality and premium car audio products in your vehicle, the Vivid Racing Diamond Audio Level 3 package is your answer. Vivid Racing has partnered with Diamond Audio to offer this Level 3 car audio enhancement package to directly replace your OEM door speakers with better quality, better sounding car audio components, add 2 12" subwoofers, and bring all the power from Diamond Audio's premier amplifiers. This Level 3 kit features the Diamond Audio D6 6.5" component set for the front and rear speakers. Next we add 2 10" D3 subwoofers and to power these a D1 400 watt monoblock amplifier. The D6 front speakers are powered by D3 Amplifier featuring 4 channels and 500 watts.
    Something different. That was our goal with the new D6 convertible systems. The bass unit uses a butyl rubber surround attached to the same hard-anodized alloy cone that is found on our D6 subwoofers. This cone is lightweight and has the strength needed for tight, accurate midbass and smooth overall response. The frame is made of a high density proprietary composite ABS and is very rigid. These systems have the unique ability to be used as either a component or a coaxial speaker. Depending on your requirements, the tweeter can be installed separately or mounted directly to the midbass/ midrange driver. With the option of either a 1” silk or aluminum dome tweeter you can choose the type of sound that fits your musical taste. Our model specific crossover with RAF (Rear Acoustic Fill) allows an additional pair of speakers to be added without adding another amplifier. The new D6 speakers are the definition of flexibility.
    Like our D3 amplifiers, our D3 series 2 subwoofers are the definition of value and performance. With large 2.5” dual voice coils, available in 2 ohm or dual 4 ohm, beautiful polished back plates and dual spiders, with woven tinsel leads, these subs have features found in much more expensive models. All D3 series 2 subwoofers handle up to 400 watts RMS. Our proprietary aluminum dust cap pulls heat away from the voice coil so they play louder, longer.
    The perfect blend of value and performance, is our combination of the D1 and D3 amplifiers! With a newly designed heat sink that features 25% more aluminum than the previous generation, these amplifiers are capable of considerably more power than ever before without increasing their overall size. On board 12dB per octave continuously variable crossovers and up to 12dB of bass boost make them very flexible.
    Level 3 Kit Includes:
    Front D652s - 6.5" Component Set
    Rear D652s - 6.5" Component Set
    S104 - 10" Dual Voice Coil Subwoofers
    D3 500.4 - 500 Watt Four-Channel Amplifier
    $1789 Shipped
    Vivid Racing has put together these car audio packages to enhance your vehicles sound system from the stock quality. We have chosen to partner with Diamond Audio, a Arizona based manufacturer of speakers, subwoofers, and amplifiers. Diamond Audio has several different levels of products to give your vehicle a crisper, cleaner, and more "thumping" sound. Each one of our audio packages includes the direct replacement sized speakers to upgrade your vehicle. We have spec'd out the best size speakers and/or amplifiers to work in your vehicle to produce a great sound system.
    You can view all our Car Audi Kits Here -
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: Vivid Racing brings you A4 specific Audio Enhancements by Diamond Audio!
    This stuff is so good, it had to be posted twiced
    Fixed! Our apologies.
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Better than Bose?
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Is the rear deck sub enclosure something that was one-off custom and we get our own box, or do you sell that enclosure separately?
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    The rear deck subs are not even in a A4...
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    thats a pretty good price for stage 2.... quality though?
    Sep 01 2008
    San Diego, CA
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by forevraudi View Post
    Damn...that is a pretty big warning
    Sep 01 2008
    San Diego, CA
    think they're trying to tell you something?
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    its only for warranty issues and to protect dealers rights to sell, i used to sell diamond audio it is nice stuff, i have found some speakers that are better called RE audio illl never look back...
    Apr 30 2007
    ohio
    diamond is good stuff. put a ton of it in. and dude your gonna have to put more than 400 watts on those 10's. hell we put the d3 800 watt amp on single 12 d3's every day and they love it.
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    So are the speakers in the level 1 kit designed to be used with the factory Bose amp?
    I love Diamond's speakers, my friend has about 10 of them in his boat and it sounds GREAT.
    -Darrick
    Veteran Member Four Rings cruzin210's Avatar
    Dec 28 2005
    Former: B6 A4 1.8TQM
    Palo Alto
    Maybe I missed it but, since the stock speakers in a B6 are 6.5's these will require new rings correct?
    Black and Silver...thats it
    Quote By rds0000:
    "I actually prefer that this little t**l speaks this way, because in an otherwise anonymous environment, it really helps paint a nice picture of who is spewing this nonsense"
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    Exactly what I was thinking ... why go down to 5 1/4 when you can run a 6 1/2 ???
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Because this is a "A4 Specific" speaker upgrade...
    Quote Originally Posted by vividracing View Post
    Sep 01 2004
    Vancouver Canada
    Quote Originally Posted by 400HPA4 View Post
    Exactly ... so they "researched, read, and assembled" the wrong size speakers ???
    Nov 14 2006
    Gig Harbor, WA
    Quote Originally Posted by me
    -Darrick
    Albeit the warning, we are in fact an newly AUTHORIZED installer/distributor of Diamond Audio. They've had too many international based companies trying to sell their products, hence the warning. Rest assured we are 100% authorized to sell and distribute the brand!
    Nov 14 2006
    Gig Harbor, WA
    Quote Originally Posted by Capt. Obvious View Post
    So are you just choosing to ignore this question or what?
    -Darrick
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    You are not listed on thier website as an authorized dealer
    Quote Originally Posted by Diamond Audio Website View Post
    NO OFFICIAL DISTRIBUTOR OR RETAILER SELLS DIAMOND AUDIO PRODUCTS ON THE INTERNET
    Definitely not trying to ignore your post, please do not take it that way. The stage 1 is for non-bose systems ONLY. If you do in fact use the Bose system, you cannot integrate the Stage 1 package without upgrading to an new amp.
    We're in the works right now with Diamond Audio to be listed on their site as an authorized dealer/installer. As we're not just an "online retailer" we also have a walk-in store and full service installation bay...
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Diamond still tells us not to trust you...their main page states that "NO OFFICIAL DISTRIBUTOR OR RETAILER SELLS DIAMOND AUDIO PRODUCTS ON THE INTERNET"
    We wouldn't even bother making a post if we didn't have full authorization FROM DIAMOND AUDIO to sell/distribute their products. By all means, I invite you to contact them directly, 480 820 2075. Ask for Brian. Feel free to tell them Vivid Racing is selling their products online, in fact, feel free to even have Brian reference my (as in Tony from Vivid) and his conversation regarding factory A4/A3 amp compatibility without upgrading to a new amp.
    Anyone on this forum is more than welcome to inquire with them to verify the validity of Vivid Racing as a company, and as a distributor of their brand.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    So these components are a direct bolt in?
    Yes, each vehicle application (as there are more app available than just what's provided for Audi) have their sizes pre-selected, with the expertise of the staff AT DIAMOND AUDIO. No fab work/fitment adjustments are needed to the factory interior components to allow proper fitment.
    Let me know if there's anything else I can help answer
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    that yes answer apply to all the diamond audio packages(level 1, 2, 3) for the a4?
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Quote Originally Posted by Maverick View Post
    This applies to all stages, for all pre-made staged packages for all vehicles Diamond Audio has supplied these packages for. Do keep in mind though, that mounting solutions of the amp, and subwoofer, as well as a head unit are NOT part of these packages. These are for core components.
    Sep 23 2006
    Houston TX
    What about non-Bose systems that upgraded to RNS-E HU for the level 1 kit?
    Quote Originally Posted by Ill 3.0 View Post
    As long as your vehicle is not equipped with any factory amplifiers, you can upgrade to the Stage 1 and run directly off of the RNS-E HU
    Veteran Member Three Rings kwik_shift's Avatar
    Aug 28 2008
    2020 SQ5
    Lake County, IL
    Quote Originally Posted by Killerteve View Post
    Those subs look like Punch, not even Diamond
    May 03 2007
    german
    heaven/hell
    as my factory BOSE stereo ages, I am consider a nice upgrade but relatively in-expensive. Level 2 package is what I like since Level 1 doesnt work with BOSE( BOSE suck, i know)
    where can I get the mounting solutions for the level 2 package?
    lastly, I am not into a loud stereo or any crazy low end bass, I want a stereo that is high resolution which means the sound clarity is very high. does Diamond satisfy that?
    Mounting solutions are going to be have to be left up to you or your installer. I'd highly advise consulting an MECP certified installer, or any local reputable car-audio installation center to help with that. There are MANY sub-boxes and areas where you could potentially put an amp...
    In regards to the clarify/quality of the sound, I highly advise any Diamond Audio components to help clarify your sound, especially in the mid-to high sections. The sub will help supplement your low end, that can always be tuned. The speakers alone will not be deep bass component speakers. As with most higher end audio components, they're geared for great acoustics that are versatile for many genres of music.
    Nov 14 2006
    Gig Harbor, WA
    Since you'd probably rather have the opinion of the guy that isn't trying to sell these speakers to you, I would absolutely say that the Diamond speakers will satisfy this requirement. From my experience with them, they are very high quality speakers with excellent sound clarity. Of course, like anything of this nature, you results may vary based on how you mount and tune your setup.
    -Darrick
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I have had Diamond speakers in the past and they are decent...what I am more concerned about is advertising a set of speakers as being specifically designed for the A4 when in deed they are not.
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    Yeah, I'd like a bit more explanation about why we should put 5.25" speakers in a 6.5" (6.25"?) hole.
    -Tim
    Quote Originally Posted by sandspeed View Post
    Apologies for the mix up in sizing, the thread has been EDITED and proper linking set up.
