Results 1 to 11 of 11
    Registered Member Two Rings b6-sr20det's Avatar
    Dec 27 2007
    radiator replacement question
    So it appears that my radiator crapped out and is now leaking coolant pretty good. So i just picked up a replacement radiator and im now pretty stumped on how to replace it. Ive beeen searching numerous forums all day and i havent read 1 helpful thread on how to do this.
    Does the whole front of the car realy need to be taken apart and swung open like the timing belt DYi that i read(the only helpful one lol). Or can i do everything from the engine bay like a normal car that im used too? If any one could give me any helpful info i would greatly appreciate it!
    Buncha motorcycles
    Memphis, TN
    Re: radiator replacement question
    i think with the way its mounted you need to pull the front bumper which is all of a ten minute job anyway
    APR Stage 2/AWE Intake
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    It has to be swung out IIRC. Just go ahead and kill 2 birds and do the T-belt also.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Dec 27 2007
    I honestly would but i need to get the new rad in asap to get to work and i dont have a t-belt kit
    Buncha motorcycles
    Memphis, TN
    taking the bumper off and swinging it out is very easy IMO.. first time might take you an hour but after that, its cake
    Mar 21 2006
    Lakeland, FL.
    Agreed, I think I can have mine off in about 15 mins.
    I'm back bitches!
    Buncha motorcycles
    Memphis, TN
    have a few beers, always speeds up my repair times
    Dec 27 2007
    Quote Originally Posted by Papachristou View Post
    Thanks dude!
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Drain coolant from lower rad hose disconnect upper and lower hose and im pretty sure you can remove it without removing the rad support at all but its been a while since i did it. Bleeding air out of the system will take you a little while. Any problems shoot me a PM.
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    Quote Originally Posted by vdubstreets View Post
    much easier to pull the coolant temp sensor at the bottom hoes to drain your coolant.
    good luck pulling those hoses off if they've never been off before, thats the hardest part of the whole job.
    Mar 21 2006
    Lakeland, FL.
    ^^^Agreed on both points.
    I'm back bitches!
