Results 1 to 8 of 8
Thread: bad EGTs
    Veteran Member Three Rings Blue_S4's Avatar
    Feb 26 2008
    1968 plymouth roadrunner 440+6
    Rockford, MI
    bad EGTs
    I have both EGTs that are bad. is there any downsides to having either EPL or VAST code them out with either one of their tunes? or is it best to just buy new EGTs and a normal tune.
    Thanks
    B7 RS4...mmmm.
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Re: bad EGTs
    I would highly recommend keeping your EGTs. They are there to protect the motor if exhaust temps get too high. It will tell the computer to dump fuel to cool down the engine.
    We have both in our store. http://www.jhmotorsports.com/shop/ca..._56_60_100_155
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: bad EGTs
    Quote Originally Posted by Blue_S4 View Post
    Thanks
    You want to get those replaced. That's one of the sensors that people install to properly tune a turbo car. There's no reason to get rid of it.
    Those sensors give vital feedback to the ECU on how the car is running, and will be able to help save itself from destruction, if temps get too high.
    Right now your EGT's are internally shorted. So the ECU only sees one reading from the sensor. That's one of the reasons why you're only boosting 5psi.
    ... I know, b/c I'm the guy that worked on your car.
    Feb 26 2008
    Rockford, MI
    Re: bad EGTs
    Quote Originally Posted by djwimbo View Post
    sweet! glad you are on here. so are both needed to be replaced? or just one of them thats bad?
    B7 RS4...mmmm.
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: bad EGTs
    how do you know if yours egts are bad?
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Re: bad EGTs
    Quote Originally Posted by 00s4slvr View Post
    It should throw a code for EGTs. You may also have random mis-fire codes.
    Bad EGT = Erratic Flooding (Most of the Time) = Misfires
    Lots 'o Goodies
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: bad EGTs
    oh then im fine for now (knock on wood)
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: bad EGTs
    For starters you'll have DTC's set for the EGT sensors being faulty. In the OP's case his CEL actually isn't on, or wasn't when I scanned it. You can go into the data blocks for EGT sensor output and verify the temps. The OP's case is that both are shorted and read 1035*C continuously.
    Both of them.
    If I remember correctly you had an SAI code and a couple others as well. I don't have access to that info at this point. The driver's side EGT isn't that bad to get from the top, but in my experience you have to get the SAI pump out of the way. So if you replace that at the same time, it's not really any additional labor, only the cost of parts.
