Results 1 to 27 of 27
    Senior Member Two Rings HotRod1200's Avatar
    Sep 25 2008
    Mk4 Supra, 2011 HD Road Glide
    NoVA
    Repairs/maintenance never ends.....
    I was warming my car up yesterday morning and noticed a strong burning smell. I get out to check wassup and see a lot of coolant dripping under the car. Its leaking in the front near the bumper (driver side) and some white smoke/steam coming from under the engine near the oil cap side. I also noticed that the front of my radiator was wet so I'm assuming that's the problem. Could it be the one of the hoses? Water pump? Aux pump?
    A few days ago my fan was making a clicking noise too. Sounded like a playing card was stuck in it. Could that have anything to do with my problem now?
    I only had this car for about 2 months and already spent about 1K in repairs.
    -reflashed ecu for stage 2+
    -replaced 2 worn hoses cuz they were causing vacuum leaks
    -alignment
    -replaced all 4 tires due to bad alignment
    Now this coolant leaking problem. Once I fix something, another thing goes bad. I just cant win
    I LOVE MY CAR! I LOVE MY CAR!
    "My car is like a wife…she annoys the living crap out of you sometimes but you learn to just put up with her sh**!!"
    EPL / TiAL 605 RaceCar (SOLD)
    SSP Tuned Stage 3 B5 S4 (SOLD)
    Registered Member Two Rings
    Mar 05 2008
    2001.5 Black S4
    SLO, California
    Re: Repairs/maintenance never ends.....
    Could be ur aux. H2O pump hitting ur timimg belt making that clicking sound. Mske sure that it's note b4 it's drivin again
    GIAC Flashed ECU++++FORGE 007 DV's++++ECS 2 piece Front and Rear Rotors++++SS lines++++VOGTLAND GT's
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by j_korteS4 View Post
    Huh?
    08 S4- Stock SOLD
    Aug 06 2008
    Canadia
    mabey that ECU reflash was not very prudent of you.
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Four Rings SLC_S4's Avatar
    Jul 15 2007
    2001.5 S4
    Utah
    Quote Originally Posted by MacDaddy View Post
    I agree....are we including the price of the reflash in the $1k of repairs? Because I'm pretty sure that reflash wasn't necessary. As far as your coolant leak.....I have no idea.
    -Seth
    APR Stage 3 - APR Stealth exhaust - APR downpipes - APR Bipipe - APR snub mount - AWE side mount intercoolers - AWE LWFW - RS4 clutch - ITG panel filter - JHM Shifter - Startup Racing Vogtland GT coilovers - Stern adjustable control arms - Fiber Images vented carbon fiber hood - Fiber Images carbon fiber fenders - Recaro Style Topline seats - A bunch of other stuff I can't remember
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by HotRod1200 View Post
    -alignment
    You own a very complex german car, *lol* consider yourself lucky if thats all you've had to replace so far.
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I'm assuming the reflash was included in your price so that was voluntary on your part.
    What ever company you had your ecu flashed with should of explained to you about the importance of checking over your car to make sure it can handle the increased boost pressure because of flash. Our cars are getting older by the minute and that means worn out rubber that can break faster with more stress.
    This doesnt mean you shouldn't of flashed your ecu, it just means you should expect to give your car the proper maintenance to handle the increased pressure on the engine components. In reality the money it will cost you to fix things if and when they break.
    Does the chip have anything to do with your coolant leaking??? Good question, I would say it just happens to be a cooncidence.
    About cost of our cars, they dont have to be that expensive if you can do work yourself. If you have to pay to have things fixed or replaced it can get very costly.
    Hope the best for you and try and think about the times when it puts a smile on your face not the anger or shock it does to your wallet.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Coolant leak could be anything, i'd advise getting it thoroughly checked over one way or another before driving anymore if at all possible. Don't let a small problem cause a big one.
    Oh, and hang in there. My first 6 months of ownership was "catch up" from the last owner and getting everything perfect, my way. Since then, it has been perfect, not that it ever caused me a problem, honestly.
    There will always be maintenance, but it should calm down once you get the essentials sorted out (boost/coolant/oil leaks, timing belt, suspension etc).
    Should.
    Brilliant Black 2001 S4 - 6MT <3
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    Quote Originally Posted by JackalS4 View Post
    haha yeah the first 5 months of my ownership was a lot of catch up to say the least!
    '00 Nogaro Blue S4
    Veteran Member Four Rings Quattrocket's Avatar
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    -alignment
    Like they said before the re-flash isnt really a repair, and the alignment thing happens on every car, same as the tire wear, and the hoses are cheap but unfortunately boost leaks are a problem on any turbocharged car.
    It's like they say, "You gotta pay to play." If your not willing/able to put the money/work into the car then I would sell it and get a japanese N/A car because this one will sink you.
    MITCH
    "Audis are like strippers. They only work when you throw money at them."
    FORGE MOTORSPORT DVs*K04 TURBOS*034 TURBO INLETS*STAGE 3 SOUTHBEND CLUTCH(MANGLED PP MOD)*
    Active Member Four Rings EUROTEK//S4's Avatar
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    Tell me about it...latst week I did @ Audi stealership
    1-Cam Seals
    1-TB Job
    1-Timing Belt Job
    Misc. Parts
    $2700 - aftermarket warranty co.
    $700 - me
    Next is front brakes,tires,..
    01' B5 S4 STG.II TIP
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    -alignment
    Alignment and 4 worn tires could have happened to any car. Also if you only had your car for 4 months you should have been able to tell the tires were worn when you bought it so the tires would be in the list of "to buy soon".
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    I spent almost $3k in maintenance/repairs in the first 3 months of owning the car. Thats not including the springs/struts, spacers, tint, dv's, boost gauge and pod, etc....thats just in repairs and maintenance. Consider yourself lucky! lol
    Hang in there man. Im sure youll have to spend another $1k before getting it right, but its worth it in the end. I almost gave up on it a few times and im glad i didnt. Of course it really helped that i also have some Japanese reliability in my driveway as well, so i always had another option.
    As far as your coolant leak...it could be so many things so i dont really know where to start. If you cant find the leak then id take it to a competant mechanic. Good luck man!
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Sep 25 2008
    NoVA
    Well I knew what I was getting into when I bought the car and how EXPENSIVE it was to maintain. I'm playing the catch up game just like how some of you said.
    I started my car up yesterday to trace the source of the leak. Let it idle for several minutes and NOTHING! Couldnt see anything leaking...so Im like
    Today, I went to the shop and told them about my coolant problem and to check the cooling system for leaks. I also instructed the tech might as well check for any other leaks while the car is up. About half an hour later he calls me out to the bay and shows me whats going on.
    Turns out my aux water pump is bad. He also pointed out an oil leak coming from my crankcase vent valve and the oil cooler seal He told me the labor would take about 5 hours for this job. Does that seem right???
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Do you guys really find these cars expensive to repair??? I find things like turbos expensive but parts are considerably cheaper or on par with my wife's Ford Escape.
    MITCH
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Quattrocket View Post
    I think it's the frequency at which some people have to repair things on these cars that gets em..It nickels and dimes some..
    08 S4- Stock SOLD
    Aug 06 2008
    Canadia
    Ford dealers are pricey. as an example, the ford dealer i worked at charged $110/hr for gasoline engine vehcinles, and $115/hr for diesel.
    The dealer in town that does only jaguar/Land rover/bently/Aston Martin charges $109 hr, and your car gets treated alot better and comes out detailed by the wash kids.
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    $110/hr is fucking insane. I was a tech at a Ford dealership for 8 months and i believe they charged $85-90/hr, and that was considered high for the area. I think id actually get violent if someone quoted me $110/hr to work on a Ford lol
    I think my problem is that im coming from mostly Japanese(mostly Honda) cars, so im used to dirt cheap maintenance/performace parts. I also have alot of experience with Mustangs, which are also known for having relatively cheap maintenance and performace parts. To me, $3000 for a big brake kit is just assinine. I got a bbk for my Honda thats actually race ready, and for all 4 corners i spent less than $1500. Its the astronomical mark-up for Audi parts that gets me. Even the dealers are bad. I know ive complained about this alot...but they wanted close to $150 for a set of freaking trans bolts. Thats just plain retarded lol.
    2014 Fiat 500 Sport
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by mholme View Post
    Huh?
    lol, x2... Not even in that vicinity
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    Quote Originally Posted by sCeRaXn View Post
    audi dealer is $150 hr
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    -alignment
    in all honestly maybe you have a crack in your radiator? or one of the hoses sprung a leak! is what I got from reading your troubles. How many miles on the S4?
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    yeah....except your aux. coolant pump is UNDER THE INTAKE MANIFOLD ...more crappy advice from people who don't know what they are taking about in our B5 forum....hooray!
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Quote Originally Posted by ///M3 TO S4 View Post
    Scary..
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Feb 09 2007
    Charlotte, NC
    Quote Originally Posted by s42k5b View Post
    Scary..
    tell me about it..
    Sep 25 2008
    NoVA
    Quote Originally Posted by s2the4 View Post
    86K on the clock
    Account Terminated Three Rings pzp107's Avatar
    Dec 02 2007
    State College pa
    actually if he did the relocation kit it would be near his alternator, so that person isnt that stupid if you thought about it. This is assuming he is meaning that based on the relocation kit. Dont jump to conclusions.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by pzp107 View Post
    conclusions.
    You're assuming a lot in that case considering the o.p. didn't make one mention of a relocation kit.
    08 S4- Stock SOLD
