Results 1 to 6 of 6
    Jun 02 2008
    Edmonton, AB Canada
    Logs (just need input from the gurus)
    It is not a B6 nor an Audi, but i would like some more input.. if someone could take the time to look and your thoughts on my logs. Need more opinions.
    original thread is here
    http://forums.vwvortex.com/zerothread?id=4126517
    Car runs good, idle 2.xx g/s on maf, lambda idle= 0.4 partial= -6.3
    Currently only codes are and are being addressed, i know the reasons for them.
    16804 - Catalyst System; Bank 1: Efficiency Below Threshold
    18613 - Performance Malfunction in Cooling System
    VW 2003 GTI 20th AWP
    Mods:
    K04-01
    high flow kinetic exhaust manifold
    Miltec 2.5" turbo back
    APR DV
    Kinetic MBC
    Front mount inter cooler
    Neuspeed TIP
    Upsolute K04 tune
    Jun 30 2007
    Raleigh, NC
    Re: Logs (just need input from the gurus)
    timing is pretty weak to see those kind of timing pull #'s....
    in the columns labeled temperature - is that IAT? (sorry, it seems like some of your stuff is labeled differently than im used to seeing? that or i just need some sleep lol)
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Jun 02 2008
    Edmonton, AB Canada
    I just realized the first one is Coolant temp and other is IAT...
    i say delete this post plz
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by B6Lovin View Post
    first column is coolant, second is IAT
    http://www.ross-tech.com/vag-com/m_blocks/010-019.html
    Here is some info on your O2 code:
    http://wiki.ross-tech.com/index.php/16804/P0420/001056
    Do a once-over to check for leaks. Then check your O2 sensor. Perhaps you can borrow a good one from a friend and redo your logs?
    Here is some info on your second code:
    http://wiki.ross-tech.com/index.php/18613/P2181/008577
    Do a once-over to check that system. Might behoove you to replace the coolant temp sensor. I know they routinely die on the A4s and even the 2.7T S4s. That sensor coupled with a faulty O2 will definitely cause problems.
    I think these codes should be taken care of before you worry about the timing in those logs. These codes could be faulty equipment (sensor, O2, etc..) which would directly affect your logs and the performance of your vehicle.
    EDIT: just saw the last log with lambdas. That requested is pretty rich!
    -Doug
    Jun 02 2008
    Edmonton, AB Canada
    That where i finished of. Thanks for more input.
    thermostat change (my CTS is new and green), then ill swap MAF's and log.
    What can the O2 wide bands on stock vags read, cause its weird how the O2 lvl's out at 0.75.
    Is there a way to check Exchaust for leaks?
    Is it put car up and start it and listen/feel around connections for exhaust gas?
    Jun 30 2007
    Raleigh, NC
    if you're running that rich you can look for spots covered in black soot too, that'll indicate a leak as well as sound/feeling for it.
    The Awesome™
