I believe its possible to find the arm/disarm wires in the door panel.. Im just not sure where they were and the wiring info i got said at the alarm module. I do know that the wires you tap at the alarm module are the trigger wires for the door lock cylinder (its hard to explain, but I can tell by the way the car acts when i lock the doors with the remote start, the lights dont flash, only the horn honks, and its responsive when the car is on). The alarm module is located in the back right side of the trunk under the floor.. if you push lock or unlock and get near your trunk you will hear the vaccumm turn on (since the locks are controlled by air, not a solenoid). If you tapped the lock unlock wires for the rocker switch on the door, this wouldnt help you since the alarm will still be armed.
Parking lights are the orange ones in the front and your tail lights. The advantage to wiring these is they will flash with the alarm, or turn on when you start the car.. But they have to be diode isolated (research on 12volt.com if you dont know what that means). You dont need that A/C wire, you just have to leave the climate control on when you turn the car off.
http://www.the12volt.com/installbay/...518~PN~0~TPN~2 It was on the 4DR sedan part a couple pages in. It says your alarm module is under the drivers seat, ive never heard of that before so id check on that.. It also talks about the thin blue wire causing problems and its listed as a start wire and ignition wire, ull hafta ask in the forum on that one becuase my blue wire was only an igniton, making it much easier. They list all of the wires accesible at the fuse block, except that blue wire so ull hafta pull your steering column apart anyway it looks like.
12volt claims theres a transponder in the key... so idk if it were me id check by wrapping the remote completly in tin foil, becuase i believe the transponder would be at the tip of the remote. If your car didnt start then it would have a chip.
This job looks a little tougher than mine with that goofy blue wire and the possibility of a transponder... Mine took me a good two days id say, since I had never done it before. If you have never done any 12volt wiring before this would be a terrible idea to try and do just for caution and to scare you even further i attached a picture of what the steering column looks like. If you plan on doing it i can give you more step by step but this is basically the only picture I got, the others just show closeups of the same thing.
Finally, I also used wiretaps, they work good for now but they arent the greatest idea for a remote start. The wires dont draw too much current, but they arent the most reliable. If you plan to do soldered connections, add quite a bit of more time to the processs, the soldering process takes a while, but the big problem is getting enough access to the tight and short wiring harnesses, theres just no slack to work with..
Picture:
http://tinypic.com/view.php?pic=2cyi4c5&s=4
