Results 1 to 7 of 7
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    vibration on deceleration
    im having a new issue with my car i get a vibration or higher pitched resonation sound comming from what i would assume is my exhaust on deceleration. it only happen on decel between 3-4000 rpms, does not matter if the car is cold or hot
    any idea's to bounce off of me.. im thinking something broke loose in the cat
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Senior Member Three Rings a4mafia(Red)'s Avatar
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: vibration on deceleration
    have you been doing any offroading lately???
    work in progress....
    B5 A4 2.8 FWD Transmission:
    http://www.audizine.com/classifieds/...ct=9554&cat=12
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    vibration or higher pitched resonation?
    Do you mean your car shakes? Or you get a sputtering noise from your exhaust?
    __________________
    Nov 06 2006
    garage ornaments
    southeastern pa
    no off roading
    car dosent shake.. you can feel the vibration when you can hear the sound.. no sputtering.. just the same popping noise on decel from the exhaust that its always had
    -Nic
    My Car
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    I had something like that when I had a heat shield damaged an resting on the exhaust. It was flooding here police where redirecting track down a road with about a foot of water and it tore offthe front two mounting points on the heat shield causing it to push on the exhaust. It only made noise at 3000 rpm or so.
    Nov 06 2006
    garage ornaments
    southeastern pa
    which heat shield is that the one that runs above the cat between the car and the cat ?
    -Nic
    My Car
    Dec 20 2007
    iowa
    It was the one right behind the tranny in between the drive shaft and the exhaust but it almost sounds like you have a similar issue. If it sounds like it is coming from under the hood check there.
