Results 1 to 22 of 22
    Established Member Two Rings mountainsnbirds's Avatar
    Nov 25 2008
    05' S4 Avant 77' Puch Maxi
    WVU, Morgantown, WV
    Fog in headlights: B6 avant
    Anyone else have trouble with condensation building up inside the the headlights. Any suggestions or quick fixes?
    Thanks
    Thanks Guys. I still need to do the operation. I bought some lithium grease. Im going to try sealing the o-ring.
    Last edited by mountainsnbirds; 11-30-2008 at 03:11 AM. Reason: update; and thanks
    Sep 13 2008
    Western Chicago Burbs
    Re: Fog in headlights: B6 avant
    I think we all have had this problem. You need to go get Some RTV sealant and seal around the headlights where the clear lens meets the black housing. Also, check the sealer rings on your bulb access covers.
    Nov 19 2008
    San Jose, CA
    Veteran Member Four Rings Fade2Black's Avatar
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    I justed picked up my new to me S4 and the dealer told me this is a common thing and that is normal.
    They are finding a fix for me.
    Dec 05 2006
    So. Cal.
    Don't seal around the lights. That's not where the problem is coming from. It's the o ring.
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    foggy lights are standard equipment on the B6
    A friend of mine has a B6 S4, and it drives him effing crazy, but I don't think it's a really big deal personally. Who gives a shit?
    what's the cure? wtf is an o-ring?
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    I think it looks cheap IMO but most won't even notice.
    Jun 02 2008
    ahhh..the deciding blow. B7 ftw! eat that fishburrito ;)
    Established Member Two Rings s4for5's Avatar
    Feb 19 2005
    05 S4 Dolphin without the Fish Mouth & about every other gas powered toy a guy could want..
    Xenonville
    fogging fixed
    I did the lithium grease all over the o-ring area mod and no more fogging.
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    Quote Originally Posted by sakimano View Post
    O ring is a circular piece of rubber used to seal pressurized or airtight connections in valves, regulators, or in this case, headlights. The O ring sits in between the removable bulb and the headlight, sealing the inside of the headlight from the outside, but since its just rubber, O rings break down regularly. For example, it was a worn O ring that made the Space Shuttle Challenger crash, I believe...
    Sold: 2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Do a search for "umbrella mod"
    Senior Member Two Rings XwalkerX's Avatar
    Dec 04 2007
    2005 s4 avant
    tuffalo, NY
    Quote Originally Posted by [email protected] View Post
    the umbrella mod is a terrible waste of time cause it just covers the top of the adjuster screw but mostiure is still able to enter the housing. the real problem lies with the o-ring on the adjuster screw. when i first bought my b6 i had the same issue but over teh summer i took the lights out used a hair dryer to completely get all the moisture out of the lights then put some new o-rings in that i got from home depot. (i forget the correct size but do a search on audiworld and you can find the thread)
    all said and done i spent less than $5.00 and took about an hour or so and i havent had any fog/mostiure issue in about 6 months.
    2004 Audi A4 Ultrasport [daily]
    2001 911 Turbo [fast]
    2005 Triumph Speed Triple [faster]
    1995 BMW M3 [sold]
    2005 Audi S4 avant [sold]
    Nov 19 2008
    San Jose, CA
    Quote Originally Posted by XwalkerX View Post
    I recently did the same fix. O-ring is a Number 6 (5/16 ID, 7/16 OD). Had so much water in the housing I could pour it out the vents. Yes, a small amount of fogging is normal, but I had drops of water covering the entire inside of each lens whenever it rained (but not anymore). Also had to dry out the housing. Pulled the lights and removed the HID capsule, then did 3-4 cycles of blowing the lights out with compressed air and heating them in a 170 F oven for 10-15 minutes. Not a bit of fogging since I did this.
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    Quote Originally Posted by ClarkSJ View Post
    i have done this repair to few b6s no more fogging
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    Glad I found this thread.
    Veteran Member Three Rings Bpitz15's Avatar
    May 07 2008
    Hartford County, CT
    just got mine fixed at the dealership. all they did was silicone around the adjustment screws and its alllll gone.
    Items for sale PM me for details:
    A6/Allroad 4.2 V8 top end
    Senior Member Three Rings Rodknock's Avatar
    Jun 25 2008
    The Dirty T, WA
    My dealer just replaced my headlights and I dont have the problem anymore.. If its still under warranty take it in. Your dealer should replace the lights at least 1 time unless its already been done..
    Jun 11 2005
    Vancouver, BC
    Terrible waste of time? Covers the adjuster screw but still allows moisture to enter the housing?
    Really? Did you even try it before you said it is a waste of time? The whole point is to cover the adjuster screw so water doesn't seep past the ring.
    I have made this for over a dozen people and NONE of them fog up. People have made this mod which costs nothing, taken their car to a car wash and their fogging issues went away.
    The original set I installed on my bixenons over a year ago stopped the housings from fogging up.
    Yes... I know the O ring replacement is the proper fix. But for a free, non intrusive fix the mod I suggested works fine.
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    is it really the oring/seal? these headlights have "drains" on the back of them, so even if you seal it up around the headlights, isn't moisture still gonna get in due to the openness of the headlight? It usually just happens to me after I was the car, prolly cause of temperature differences? I dunno.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Jun 11 2005
    Vancouver, BC
    Due to the design the rain water that runs down the side channel drops directly over the top of the adjustment point.
    The O-ring is a bit too small and allows for water to seep past and form a small pool inside the housing. When you activate the headlights the heat that is generated in the housing vapourizes the water and it condenses on the inside of the front lens.
    The vent openings on the back of the headlight are not the cause of your moisture issues.
    Veteran Member Three Rings szinkuti's Avatar
    Oct 06 2008
    Allroad Truck aka Uber UTE
    Grand Prairie, Texas
    you just have to complain enough times.....they said they wouldnt replace mine the
    first time....so after the 3rd time i got new headlights....and the new ones dont fog...ever...and i work at the dealer as a tech.....but there is a tsb and it says after like 15 of headlight use the condensation should clear up depending on humidity and blah blah blah....screw that...car is too damn nice to be rolling around with headlights full of water....
    Active Member Two Rings tomazo777's Avatar
    Jan 27 2009
    2005 S4 / 2008 Subaru Tribeca
    Utah
    hi all:
    I just got a 05 S4. I love that car.
    Can someone tell me in detail what to do with the confensation inside me headlight?
    How to get rid of it and what to do so it does not come back.
    thanks
