Originally Posted by
KPC1.8TQuat
Care to elaborate on that because I had a very different experience.
I went for a ride in my tuner's S4 with Alcons and the braking power was ridiculous. Every time he leaned on the brakes it felt like we were deploying parachutes and settling into slowly thickening cement (if you can imagine that description).
Quite the difference over stock in my opinion.
BBK's unevenly distribute the amount of hydraulic pressure required to stop the front and rear rotors. The boxster and 911 calipers require much less pressure to distribute the same amount of stopping force as the OEM calipers, and as such this leaves the rear calipers with less pressure to work with without any increase in stopping amount.
lets just say that it takes 10lbs of force to get 100% stopping force on the front oem calipers and 100% for the rear..
upgrade to bigger calipers without balancing the rear and you get this:
5lbs force for 100% front power and since we don't have as much pressure, we're only getting 50% out of the rear caliper and not stopping the car as quickly as it could. This dosen't even account for the master cylinder on the porsche's having higher pressure to better use the calipers too.
Car manufactures don't just throw brakes on a car.. lots of R&D goes into balancing the braking so that the front and rear are loaded equally and thus stopping the car the most effeiciently.
Your friend has alcon's too.. which to be honest, are not even in the same league with the boxter or 911 upgrades, and if he was smart and had enough cash to get alcons then chances are he did the rears too to compensate.
