    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    Does my timing logs look ok?
    Just took some logs of blocks 020 and 03 in vagcom...trying to get my timing right, but need some help. How do these logs look. Im currently running a FATS time of 3.61 w/ awe stage 3 setup.
    http://spreadsheets.google.com/ccc?k...1r7z8fI2CmGxAA
    http://spreadsheets.google.com/ccc?k...1r69KZ-_IGUJWw
    Veteran Member Four Rings S4-ORCE's Avatar
    Apr 16 2007
    01.5' S4 ASP Tuned
    Long Island
    Re: Does my timing logs look ok?
    3.6 for AWE is good. Timing looks okay
    Veteran Member Four Rings JMTx86's Avatar
    Oct 03 2005
    Did you log knock?
    9-12d jump is a decent amount.
    00 b5 s4 Single turbo
    1969 Chevy Nova 396 (Full resto, completed in 2016)
    1969 Chevy Camaro 454 (built 454/th400, body is a work in progress)
    11 Chevy z71 5.3 shop truck (Vortech V2 build in progress)
    May 23 2008
    Columbia, SC
    didn't log knock, but will do today. What should my goal be if 9-12 is decent? Thanks for the reply.
    Oct 03 2005
    Quote Originally Posted by Allaidback View Post
    You'd have to post more infp/logs, it all depends on your mods. If you have a FMIC you can run more timing at the higher load (rpm) but you don't want to it knock. Id say if the car is running good leave it alone.
