Results 1 to 34 of 34
    Veteran Member Four Rings GotRS?'s Avatar
    May 18 2008
    Brighter tails with VAG-COM, good with tint
    First, props to John Stahmann over on AW for finding this
    To increase the brightness of the three tail light bulbs, go into 09-Cent.Elec., choose Adaptation-10, then on Channels 02; 03; 04 you can set the brightness in % for each of Brake; Tail; Rear-Fog bulbs.
    Enter your new % value (the range allowed and standard setting come up in a pop-up info box, max is 40%), press Test then Save if you like it.
    I found all my brightness' were set much lower than "standard" so I bumped them all up to 30%. Huge difference. My tint is fairly dark and I feel much better for doing this. I think it's a good reply to have in mind if you get stopped for tinted tails. "It's a feature of the car to allow for tint!"
    Just to check one more thing, I set the brake light brightness level to the highest allowed, 40%, then pressed the brake. They still go way brighter (to 100% maybe, duh), so there is no worry that you'll have no brake lights by max'ing them at 40% brightness as tail lights. Same thing goes for rear-fogs too. There is a DRL brightness setting in a higher channel number too if you run those.
    Dec 14 2006
    2007 Audi A4 S-Line
    Long Island, New York
    Re: Brighter tails with VAG-COM, good with tint
    Nice!
    Senior Member Three Rings BLACKa4QUAT's Avatar
    Mar 26 2008
    union city, ca/fort worth, tx
    cool. gonna try this out soon
    2006 A4 2.0Tqm, S-line, tech, FH-P8000BT, 10" sub, 800 watt,
    VAG-COM mods (remote windows, no chime), revo stg 1 tweaked
    AWE pedals, HRS4 DTMs/Eagle GT, VMR TP
    193.7 awhp/232 ft/lb/91 oct pre-TP
    16MAR09DSWHTAW
    Veteran Member Three Rings barkerd427's Avatar
    Oct 04 2006
    2007 Audi A4 & a honda
    Princeton, NC
    I think this should be added to the sticky!!!
    2007 A4 2.0T S-Line Quattro / Deep Sea Blue / Black Leather Interior / Nav / Heated front seats / Xenon head lamps / APR Snub Mount / RS4 Pedal Set / RS4 brushed aluminum grille / RS4 rear sway bar / RS4 parking brake handle / Xenon match interior lighting / SOON Custom fog light grilles with S6 LEDs and RS4 mesh and brushed aluminum trim, just need to find the trim
    Veteran Member Three Rings pretarion's Avatar
    Jan 02 2007
    Plano, Texas
    Truly awesome. Thanks
    2012 Audi TTRS Carbon Package
    Veteran Member Four Rings CZA420tAvant's Avatar
    May 24 2008
    06 A4 Avant 6MTQ Brilliant Red
    Orange County, NY
    thats a great think to know
    Driving: 2006 Brilliant Red A4 Avant 2.0TQM
    Revo Stage 2|Carbonio Intake|Stasis SS coils|Podi Gauge|iForged 19"|H&R spacers|RS4 F/R sways|custom inlet pipe|Milltek turbo back with custom twin tips
    Endorsing:
    Veteran Member Four Rings TooLow2.0T's Avatar
    Feb 13 2004
    Portland, OR
    Never would have guessed this was possible. Pretty cool!
    Current: Tundra Brown 2015 Audi Q3 Prestige Quattro | Black 2013 VW Jetta
    Previous: Brilliant Red 2007 Audi A4 2.0T Quattro 6MT S-Line Titanium
    Veteran Member Four Rings gaede's Avatar
    Jun 06 2008
    fourbanger
    Carlsbad, Ca
    set rear fogs to 150% to blind tailgaters?
    i'm in.
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    I also turn on my rear fogs when someone is tailgating me, they think it's my brakes and back of. But seriously this info along with the info for one-touch indicator adaptation should be in the B7 sticky, if not already. OP, good on you for finding this.
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    Quote Originally Posted by airborneriflema View Post
    What's that?
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    Quote Originally Posted by gaede View Post
    i'm in.
    I think mine were that way when I got the car. I can use it to see when backing up.
    May 20 2008
    2013 Passat TDI
    Quote Originally Posted by ABanT View Post
    What's that?
    When you tap your turn signal indicator it blinks three times. with the use of vag com you can change the number of time it blinks.
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Account Terminated Four Rings
    Jul 10 2008
    06 A4 / 09 IS-F / 10 Cayenne
    Austin, TX
    Sorry if this is stupid, but can this be done with the $20 Vag cable or do you need the full version?
    Veteran Member Four Rings Sal_B7's Avatar
    Dec 11 2007
    2005 A4 2.0T Quattro 6Spd
    San Diego, CA
    Im going to ask my roomate about this. He is a VW Tech. Good stuff to know!! Thanks for the info!!
    '05 A4 2.0T Quattro MT APR Stage 3
    2008 APR Holiday Giveaway Winner!! Thanks APR!!
    FRRG Southern Ring
    Xbox Live ID: Sqzn2zz
    DUH! an Audi
    los angeles, CA
    ill go test it out soon, and see what happens sounds awesome!
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    that's a cool nugget
    Veteran Member Three Rings nycmalu's Avatar
    Apr 16 2008
    Rockland County, New York
    I remember reading threads about this, but never actually saw an answer. Could anyone direct me to what is being discussed here? Searching for one touch indicator got me nowhere...
    -Steven
    CONTROL ONE: Haha, don't toy with her emotions - that's my job.
    marty was here: listen. you are an amateur.
    Veteran Member Three Rings jahciple's Avatar
    Mar 10 2008
    08b78ea42t6mtnq
    Long Beach, CA
    Quote Originally Posted by nycmalu View Post
    i tried it but couldn't find anything on the vagcom about it, even went to the help menu.
    Driver: Dustin
    Projekt: Audisciple
    Gamertag: JAHciple
    Veteran Member Three Rings bloodstar57's Avatar
    May 15 2007
    2019 RS5, 2014 SQ5,
    LI, NY
    Watching
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    Subscribed!
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Jan 27 2007
    NC
    Has anyone noticed that when you use the rear fogs that BOTH come on!!! i know mine do because Slappy verified it on our meet.
    vizi
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    Quote Originally Posted by viziers View Post
    vizi
    Both rear fogs on is standard on the B7s
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Comfort Blinking
    The feature is called "Comfort Blinking". My searching of the web showed it's only adjustable on the VW Polo. I read somewhere VW Golfs allowed you to adjust as well but didn't find anything else to actually confirm that.
    Apr 06 2005
    Boston, MA
    Re: Comfort Blinking
    Quote Originally Posted by a4audi4fun View Post
    This can be adjusted on the Touaregs 09-Central Elect --> Adaptation Channel 2. I thought that I could adjust it on my Q7, but frankly, I haven't bothered to look into it. 3 blinks suits me just fine
    Senior Member Three Rings Allan T's Avatar
    Sep 28 2006
    Audi a4 b7 2.0 Tfsi quattro avant sline
    Sweden
    Very nice find.
    Mod list = To long to write.
    http://www.garaget.org/?car=118660
    Apr 16 2008
    Quote Originally Posted by mksap11 View Post
    I have this habit of waiting a second before I change lanes, just to warn people, and by then, two of the three blinks is already over and done with. I need to change it to 4 or MAYBE 5, but that might be too much. I think 4 is good.
    -Steven
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    is there a way to make the headlights or front fogs brighter as well?
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Veteran Member Four Rings NorcalPB's Avatar
    Jul 16 2008
    Supercharged M3...sold/ Titanium B7 A4
    San Francisco
    Quote Originally Posted by 12sA4 View Post
    No, tried it today.
    Oct 16 2008
    South Florida - Ft Lauderdale
    Did not work for me. 2005.5 B7TQ. Wagcom let you enable or disable the function but you can't adjust the number of blinks. Did I miss something?
    May 20 2008
    2013 Passat TDI
    http://forums.vwvortex.com/zerothread?id=1920685
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Veteran Member Four Rings DeMOROlized's Avatar
    Sep 18 2006
    GTA Canada
    I'm almost 100% sure the number of blinks can't be changed on a B6/7. IIRC the channel for that is actually used for the tail light brightness level in our cars.
    1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
    2nd Ring: 2006
    Moro Blue B7 A4 2.0TqMS
    3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
    4th Ring: TBD
    Apr 16 2008
    Quote Originally Posted by MoroIsAnOrange View Post
    And since Moro was the main contributor on the whole VAG-COM thread, I'm gonna go ahead and believe him here... It would be nice to have that option though...
    -Steven
    May 20 2008
    2013 Passat TDI
    Your absolutely right.
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Established Member Two Rings jsilvers3043's Avatar
    Feb 14 2008
    O0oAuDio0O
    i KNOW YOU CANT do that in the a4 but Mk5 VWs you can
