Well I went to adjust the fueling a little. I am running around 13.2:1 from 2500-4800k rpm. After that it goes pretty much into my desired (.8) lambda reading.
I am adjusting the primary fuel enrichment and I was a little confused when I found out it only went up to 24.8%.
First run, I increased it to 10% and did a run. My lambda values looked the same although my boost did not hit its peak (about 2 psi short). Does that mean that since maybe I didnt hit my peak boost that I am doing something good and adding more fueling since it didnt have enough air to compensate?
Second run-I brought the value back to what it should be (0%) and did another run and I hit my normal peak psi.
What should I increase the primary to? Or what else should I increase?
