Originally Posted by
gotboost
Does it look right, is there supposed to be another lockig rings that locks against were the spring sits, and also there are no allen screws that are supposed to go into the three holes at the bottom, I called stasis and they said that sometimes koni doesnt include them, and how do I adjust the dampning on the front and rear shocks. Thanks
there is no lock ring on the rear. nor set screws for the spring collar.
the adjustment is done by compressing the shock complelty and twisting the shaft. you should feel the indentations that indicate the adjustments.
If you got these from STaSIS you might want to try them the way they set them up first before you start adjusting them.
