Results 1 to 6 of 6
    Registered Member Two Rings
    Aug 08 2008
    Spain/Dallas TX
    Pwer lock Pump Bad!!! need help
    The locks on my B5 won't work anymore and my guy at the local tuner shop said that he's seen this before and that its the vacuum pump. I was curious if anyone else has run into this and if it is able to be done by myself with basic tools.
    Would a Jetta/Gti/or a a passat pump work on my a4???
    sucks having to open your door with the key and having to tell your passengers to lock the door every time
    Oct 10 2008
    orland park
    Re: Pwer lock Pump Bad!!! need help
    My pump on my car went out before. Its in the trunk. When you try locking the doors do you hear any sound coming from the trunk?
    The pump for the central locking system is located in the right-rear of the luggage compartment under the luggage compartment trim.
    After the car has been parked for a lengthy time and/or after replacing the central locking system pump, the central locking system will not function properly until prompted repeatedly.
    When the system is operating correctly, all locks will close within 2 seconds .
    If the pump operates for longer than 5 seconds , there is a leak in the system.
    When there is a leak in the system, the pump must not run for more than 30 seconds . The pump's control unit must shut it off at this point.
    All the lock actuators are equipped with special vacuum line connectors that must lock when plugged in.
    But first
    check Fuse 38 - Its the Luggage compartment light, central locking system 15A
    And fuse 6 - Central locking system 5A
    Check your owners book for fuse number locations
    Aug 08 2008
    Spain/Dallas TX
    Quote Originally Posted by seeknstrike View Post
    But first
    yeah everytime i lock or unlock the doors i hear a sound coming from the back i know where it is.
    my question is if i can swap it out from a jetta or passat because were i live i seen them in junkyards but haven't seen audis.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    I'll ship one to you for 70 bucks...
    Oct 10 2008
    orland park
    check the part number on the pump. they are the same
    Aug 08 2008
    Spain/Dallas TX
    cool i try that thanks
