Results 1 to 26 of 26
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Need some help... again :)
    Long story short... There is one shop which was about to make a "custom" chip for me, but when they Vag'ed it, we found out that my cylinder 1 and 2 had some minor misfires. I didnt feel them at all, only on cold starts- sometimes.
    Ok, then they put it on a dyno blah bla blah and checked on a boost leak, my dv (forge 007) wouldnt pass 5psi?. I havent serviced it for 7 months already though. Now, car idles weird, very similar to a vacuum leak i had before, but a bit better. And misfires around 3k-4k.
    So before i do anything i got a couple of questions:
    could that be my DV?
    coils? i think i had only one detonation right after the start, thats it.
    spark plugs? I changed them in the summer with NGK iridiums.
    I also tried to look/listen for any vacuum leaks but didnt find anything?
    Any ideas?
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Re: Need some help... again :)
    Also, when the car warms up, idle is getting a bit better
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Bump
    Aug 10 2008
    sehg
    i had just about the same problem with my b5 a4 2.8 Quattro w/ tiptronic. back in august, cylinder's 4 and 6 misfired due to a vacuum leak that had to be fixed, as with cracked cylinder lines to both those misfiring cylinders. my spark plugs were changed just in case if that was also the case. i spent at the audi stealershit roughly 5-600 bucks for all repairs including labor?
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    so your cylinder lines failed?
    Did u do something to your car or it just happened?
    Was it misfiring bad?
    Aug 10 2008
    sehg
    I drove the car just like any normal being would, never hard. I discovered the problem a few months into owning the car, and the misfires were noticeable through idle and through cruising around town. As with answering your first question, My cylinder lines did fail as that was part of the reason to have my car fixed.
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Oh, i hope my problem is something easier :)
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Anyone?
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    For misfires, start with the simple (and cheapest) and move your way up the ladder. First thing to do is to check and change the spark plugs. Make sure they are properly gapped (even if they come pre-gapped out of the box).
    If that doesn't work, swap the ignition coils between the ones that misfire to the ones that don't. If they start misfiring for different cylinders, then the ignition coil is going bad and should be replaced. If you've never had the ignition coils replaced, it might be a good idea to replace all 4 and keep the two good ones as spares.
    If the misfile continues to happen for the same cylinders, then it's not the coils (still could be replaced, but it's not needed). It could be the injectors are failing and need replacing.
    I had to go through all 3 steps to fix my misfiring issue - had old APR Delco 550cc injectors that went bad. Replaced them with Bosch 386cc (TT225) injectors, reflashed the APR software, and have not had a misfire since.
    USP CLUB MEMBER #34
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Thanks CyberPMG.
    Update
    Changed spark plugs - nothing
    switched to Froge 004- nothing
    Tried to unplug the MAF sensor, but it still does the same thing without it..... But now i got ESP light on!!!!!!!!!
    Where else could be the vacuum leak? Cause i cant find it, and i'm 80% sure thats what it is.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Back of the intake manifold.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Quote Originally Posted by aaaudiprotein View Post
    Check out the vac diagram for our cars. It also has part nos. I've it below:
    1.8t vac diagram
    Hope this helps u find the problem.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Thanks guys, gonna see watsup tomorrow
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Well couldnt find anythinggggggg, now my ESP light is always on!!!
    What could that be? I also cleaned my MAF yesterday.
    or could that be because i gave a jump to my friends car yesterday?
    Veteran Member Four Rings NightRoller USP's Avatar
    Aug 23 2008
    2008 Rs4
    What year is your car???
    I was at the dealer one day and they told me they had to update my ecu because i would get missfires on cold starts!
    Dont know if this is benneficial to you, might be something you could check into.
    Jacob
    AWE ll APIKOL ll PODI
    USPCLUBMEMBER#190
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    mine is 03. But my problem is somwehere else, i'm sure about that!!!
    May 13 2008
    NoCal - EBay
    Doesn't the ESP light stay on if the MAF is unplugged
    Also maybe I missed it but I couldn't find any mention of ur coils - are u still stock???
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    ^^^ yeah, i fixed that ESP problem for now.
    But still having the misfiring issues. Yeah, still stock, but i checked all the coils and it didnt help.
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    VAGCOM results:
    Random/Multiple Culinder misfire
    p0300-008
    Cylinder 4:Misfire Detected
    p0304-008
    Cylinder 2: misfire detected
    p0302 -008
    Fuel trim; bank 1: system to leam
    p1128 -001 -Mil On
    Fuel Trim Bank 1: system to lean
    p1136-001
    Cylinder 1 ignition circuit: open circuit
    p1355 -004
    Cylinder 2 ignition circuit: open circuit
    p1355 -004
    Cylinder 4 ignition circuit: open circuit
    p1364-004
    Cylinder 3 ignition circuit: open circuit
    p1361-004
    Mass Air Flow Sensor )g70); signal too low
    p0102-002
    Those in red are prolly cause i was playing with coils/maf while car was on, but what about the other ones? Vacuum leak?
    Feb 23 2004
    Stow, OH
    Swap the coils. Swap the coils between cylinders 1 and 2. Swap the coils between cylinders 3 and 4. Clear out the codes. When you get misfires again, do another scan. Are the cylinders that are misfiring the same, or did they change? If they changed, then the coils are going bad and need replacing.
    If the misfire remains with the same cylinders, you may need to replace the fuel injectors for those 2 cylinders.
    Both are easy to replace.
    The open circuit codes would have been when you were playing with the MAF. It wouldn't be a vacuum leak.
    USP CLUB MEMBER #34
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Update again!!!
    After 1.5hrs of Vagging and thinking, testing fuel pressure and etccc, my mechanic came up to conclusion that my MAF and o2 went bad. We replaced MAF and its a bit better noe accorfing to VAGcom, tomorrow gonna try to replace the o2 sensor.
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    Who's making the custom tune?? around the burbs?
    789whp
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    I dont want to name the shop yet... But yeah, in da burbs :)))
    But i live around Glenview, so i take my car to MobileOne all the time to fix something
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    just curious, but if your MAF and 02 sensor went bad how many miles do you have on the car? this isn't uncommon at around 85K miles and up.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    Why? are you the beta tester?
    789whp
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Quote Originally Posted by LampyB View Post
    Turned Adult yesterday (100K). What couldve happened is i put a cone filter before the summer, and had NO heatshield for all that time.
    Something like that, if u are that interested, pm me.
