Results 1 to 6 of 6
    Jun 26 2005
    Ft. Lauderdale
    car pinging question.
    I have the gtrs kit. run 93 octane. I have the sps set to 6. When i punch it, I hear like a clicking noise. Is this pinging? It is happening in the higher rpm's with around 17-20 psi of boost.
    What damage can this cause? Will it hurt anything if just for a few seconds to let off the gas? Is it possible something is damaged already?
    It doesn't sound good. How do i fix this? lower the timing or increase the octane?
    gobble gobble
    Veteran Member Three Rings Drew-B6's Avatar
    May 15 2008
    Syracuse, UT
    Re: car pinging question.
    What spark plugs are you using also do you have a full exhaust and FMIC?
    Drew-
    2013 Audi S4
    Jun 26 2005
    Ft. Lauderdale
    Yes i have fmic and a no cat 3 inch all the way back. Not sure what plugs they are although they were recommended with the setup.
    Buncha motorcycles
    Memphis, TN
    have you logged it?
    APR Stage 2/AWE Intake
    Jun 26 2005
    Ft. Lauderdale
    what should I log? Should i start logging until i can capture that pinging again? or should i avoid the pinging noise..
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Put your timing setting down to 1 and see if it's still there.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
