Results 1 to 17 of 17
    Senior Member Two Rings stllboostin's Avatar
    Oct 06 2006
    tapp horsepower ques...
    what is the most hp/tq anyone has gotten from a tapp 630cc file with a 3071 or 3076 on pump gas ??????
    avantpwr
    Senior Member Two Rings Bigjuice's Avatar
    Dec 31 2005
    Atl
    Re: tapp horsepower ques...
    I got 330whp on pump @17psi..
    450whp on C-16 @ 30psi
    This was using a 3071R
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Quote Originally Posted by Bigjuice View Post
    Seems high for the 3071 where's the plot? Your setup is not typical so you're results are well above the norm IMO.
    Dec 31 2005
    Atl
    Quote Originally Posted by bassed View Post
    I had Cams, & that boost was higher than what was set.
    The hose on the gate came off, so 30psi was what came up on the data log.
    When that was fixed, I set it @ 25psi & that registered 430whp....
    Logs are somewere in the archives here..
    Veteran Member Three Rings 1NaudiA4's Avatar
    Feb 13 2007
    98 A4
    Chicago
    a 120whp increase from race gas? I could only imagine that being possible with 35r+ turbos. I gotta see a graph to believe it.
    Oct 06 2006
    are these numbers with tubular mani or log style......has anyone without cams seen 400 whp on pump
    avantpwr
    Dec 31 2005
    Atl
    http://www.audizine.com/forum/showpo...&postcount=106
    This was with a tubular Jay Thornton manifold, Cat 3653 cams, 630cc tune.
    The actual whp was around 425, the 450 was recorded when the hose broke, so I suspect that was 30+ psi.
    It held together well, no problems, but that was too scary for me.
    Jan 25 2006
    A4 2.0T
    MD
    The return of Big Juice!!!
    He also ran 12.2 IIRC.
    Dec 31 2005
    Atl
    Quote Originally Posted by Don Supreme View Post
    That was with bent valves....
    Starting something new soon
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    O rly?
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Not to steal the thread but, Don Supreme, by any chance you have a vid and turbo set up you were runnging for the times you have on your sig? 12.1
    thanks
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by pipe7284 View Post
    thanks
    lol look on his thread, I did commentary against the M3... he also has a 2nd-3rd gear pull vid on there... more videos coming soon tho, its a bit faster now
    - Clint
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Sounds about right to me assuming you have a really good tune (which I'm sure you do). I pick up ~50-80whp on race gas and its a completely separate file written for that fuel.
    Just because he is not a regular poster doesn't mean its not the 'norm'. Its completely feasible with a solid tune.
    -Doug
    Jan 25 2006
    A4 2.0T
    MD
    I thought you were selling?
    Dec 31 2005
    Atl
    Yes,I sold it....
    Jan 25 2006
    A4 2.0T
    MD
    Yes,I sold it....
    So is the new project another 1.8t A4 or what?
    Sep 24 2005
    always in design
    Read it again. I said his setup is not typical, so the results are above the norm He has a 2.0L, Cams and a Thorton Mani.
