Results 1 to 11 of 11
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Can someone convert/interpret these logs? (71r)
    Just ran some logs on eakrob's car tonight. He doesnt think its running right so we went and ran some logs.
    He has a gt2871r eliminator
    ctapp tunning
    630cc injectors
    not so sure what MAF
    Upgraded fuel pump
    Im sure Eric will chime in and let me know what exactly he has, but here is the raw data that needs to be converted into excel.
    Any help would be appreciated as well as letting us know how the car is running.
    These are logs of 003,031,020 and 003,115
    TIA!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jun 04 2007
    Austin/DFW, TX
    Re: Can someone convert/interpret these logs? (71r)
    tttttttttt
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Thats very hard to read......any chance you could save it as an excel file and load it onto Google Documents?
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Aww come one Chris, you gotta at least take the time to convert into a CSV file for everyone. VAG Mobile puts semicolons in there file but you gotta replace all the semicolons (;) with commas (,) then upload a CSV file or stick the data in an excel file for everyone.
    There is a tool someone posted a little while back that will allow you to upload your newly created csv file and it would generate a picture for you that you can post in the forums for help.
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by GetBoosted84 View Post
    Well normally when you go to Excel you just copy and paste that data into the first cell, then go to
    Data-Text to Columns-Next- then under the delimmiters select "other" and put a semicolon in the blank.
    I dont know how to convert it to a csv
    Edit: Well I just put it into a spreadsheet and just took a screen shot, sorry thats the best I could do.
    My 5-Speed Swap DIY
    - B6 USP
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    You need more timing thats for sure and your actual boost reads are coming on way too late.
    AFR looks fine at .8
    Dont understand the second reading on block 003, should be maf readings but your readings are way too high for what they should be. You are running a 3" maf with the stock maf sensor right?
    Jun 04 2007
    Austin/DFW, TX
    They are the MAF readings.
    Its a s4 hithachi sensor , 3" housing
    My 5-Speed Swap DIY
    - B6 USP
    Sep 21 2007
    DeSoto, TX
    Well fellas, thanks for the info I'm gonna send my ECU back to CTapp to see if he can make these changes.
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Quote Originally Posted by biketsai View Post
    I thought tapp did lightning maf tunes only
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by t1demont1 View Post
    depends on the year
    Jul 07 2004
    socal
    For ndbw cars only. I guess for dbw he uses the S4 maf or just straight mafless.
