Results 1 to 11 of 11
    Veteran Member Four Rings RomanA6's Avatar
    Mar 01 2005
    2007 Black VW Jetta GLI DSG
    Rochester, NY
    4.2L V8 conversion into a 2.7T
    anyone knows more info on that car Vast built? or anyone else did this yet to a 2.7T?
    thanks
    story:
    had problems with my transmission; took car from bad mechanic, drove home, on way home car started overheating, then turned off and didn't start block away from home; pushed the car home; sat for 1.5 years; changed transmission - went to check why no start - saw ripped timing belt
    so, this is probably a 0 interference engine, and head(s) are toast, and who knows what else down in the belly of the beast; so maybe a 4.2L V8 isn't that bad of a solution?
    not in hurry to fix or anything, and won't part out; just another long term project
    if I remember right, Vast did a transplant, and that car was still geting good 30mpg "back then" because car was a 6-speed
    Senior Member Three Rings a4mafia(Red)'s Avatar
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: 4.2L V8 conversion into a 2.7T
    you should look into a biturbo v8.....that'd be soooo sweet!!!
    work in progress....
    B5 A4 2.8 FWD Transmission:
    http://www.audizine.com/classifieds/...ct=9554&cat=12
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    damn 30 mpgs with a 2 7 or 4 2
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Nov 19 2005
    Pair of (. )( .)
    vast did a 4.2 from s8 in c5 4.2 with 6 sped manual, you on the other hand have a 2.7t body with shorted front end....but it was a b5 with 4.2 so i would say its possible, but maybe just better to fix your engine and do a stage 3 ;) it should be less headacke and less money.
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    You would probably need to source pretty much the whole front end. The 4.2 is like 3 inches longer in the nose. Thats why the lights, hood, etc don't fit on regular body C5's.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Mar 01 2005
    Rochester, NY
    Quote Originally Posted by kievskiy View Post
    I thougth everyone was saying that they did it to a 2.7T? and yes that's the car
    Nov 19 2005
    Pair of (. )( .)
    ^ maybe, i think they still have a video of it on their website.....hmm, i need to look up, i was sure it was 4.2 body....
    -Andrey
    Veteran Member Four Rings ENDEE666's Avatar
    May 04 2007
    A6 2.7T 6MT Modded. Allroad 2.7T 6MT.
    LI,NY
    I am almost positive they started with a 4.2 as well.. I mean, just look at how little room you have in front of the 2.7 and imagine an engine 2 cylinders longer...
    01 A6 2.7T, blk/blk, 6MT, SSP Tuned!, 3,996 lbs w/ me, full weight, street tires, 29+lb wheels.
    Ran an 11.8 @ 119 at MIR - Sept 2008. FIRST A6 IN THE 11's!
    Also 04 Touareg 4.2 89k with 22x10s
    Nov 19 2005
    Pair of (. )( .)
    yes, it is 2000 4.2 body, here the race between b6 s4 and Vast A6
    http://videos.streetfire.net/video/B...-A6_157185.htm
    -Andrey
    Veteran Member Three Rings slmds4's Avatar
    Sep 22 2005
    2022 Audi SQ5
    Atlanta
    Damn that vast a6 sounds like a beast
    Mar 01 2005
    Rochester, NY
    that is not the car I'm talking about
    on their website they have a silver one under projects, that's not the one either
    they had a light colored one (silver or maybe tan like your's and mine), when they first put the video out (or someone found it) it was a C5 A6 and everyone (atleast thought) that it was either a 2.7T or a 2.8 body, but it said a 6spd in the video so it must have been a 2.7T
