98 1.8t , stock motor...
gt30 with all support bolt on parts.
Here is the problem...
i have been noticing that i will lean out under WOT...4 gear pull.
up to 5k at WOT i see low to mid 12... as the RPM still climb.. AFR will raise to 13 sometimes see 13.5.
My question is , is this normal.. ?
just to answer everyones question... i do have a walbro fuel pump, brand new at that time! TAPP software with 630cc. Ford Lightening (ebay) MAF.
i also running an adjustable FPR.. right now im sitting at 56psi which is above 3 bar as recommended.
I just cant see how i can do to solve this issue, if it is an issue?
OH one more thing... i recently installed v6 Throttle body and yes its adapted.
Thanks guys,
JOHN
i have a feeling if i continue with it as it is.. im going to blow that motor .
