Results 1 to 40 of 40
    Senior Member Three Rings a4mafia(Red)'s Avatar
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    supercharged 1.8t
    okay first off, this may be a completely stupid question.....i was wondering if anyone knows if its possible to supercharge a 1.8t.....i'm not talking about taking off the turbo, but instead keeping it and adding a supercharger.
    ps. i searched for this on google, audizine and other locations but could not find anything about it that kept the turbo on.
    thanks in advance
    justin
    work in progress....
    B5 A4 2.8 FWD Transmission:
    http://www.audizine.com/classifieds/...ct=9554&cat=12
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Re: supercharged 1.8t
    i believe this is what you're looking for
    link
    __________________
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    not quite...i have heard of these turbonators before, but it does make me wonder what it'd do for a turbocharged car :D....probably nothing bc the point of them is to atomize the air and a turbo already does it. maybe it would help with boosting faster..... i was thinking along the lines of centrifugal(sp?) supercharger?
    Veteran Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    Quote Originally Posted by le91688 View Post
    link
    ROFL
    it's so easy to install a girl in a white bikini could do it!
    two thousand two audi a-four quattro five speed
    Veteran Member Four Rings FLACO X3's Avatar
    Jun 05 2008
    B5S4, B7A4
    Thornton & Elbert County, CO
    you mean twincharging right? a turbo and supercharger combo. IDK of any Audis like that, but I read in a past issue of Euro Tuner of a BMW 325i with a centrifigal supercharger from an Isuzu truck and a GT30 turbo. Only put out about 400 hp. But it was very mild tune I believe.
    2000 S4
    2008 A4 2.0TQ
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Quote Originally Posted by FLACO X3 View Post
    yes twincharging. thats interesting, even with only 400 hp wouldnt it still be pretty quick bc its got 2 "turbo chargers" on it?
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Not the right forum...
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    someone has something in the works right now. wrong section of the forums to post under.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    You're referring to "Compound Charging."
    Very possible, some manufacturers dabbled with compound charging, one that comes to mind is Lancia.
    The idea was to make a small capacity engine feel like a "larger" one - the supercharger took care of bottom-end power, while the turbocharger took care of top end.
    The switchover was seamless, so it gave a very smooth power delivery.
    Besides the obvious mounting issues, the hardest thing to get right is the "phasing", in terms of software that controls the lot.
    Generally, both are not boosting at the same time, so the switchover needs to be very carefully monitored / controlled, so the graph shows no dips - i.e, there's no "gap" where the supercharger boost pressure drops off, and the turbocharger boost takes over.
    A lot more complicated than even fitting twin turbos to an I4.
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Quote Originally Posted by t1demont1 View Post
    my bad guys. i wasnt sure whether it was tech talk or not......ONCE ONE PERSON SAYS IT, I DONT NEED 10 MORE TO SAY IT TOO. thanks
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Typing in all caps does not help you get your point across.
    __________________
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Quote Originally Posted by Siena View Post
    so its definitely not worth trying to do i guess, thanks
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    true. but it catches your eye better
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    look at the lancia delta s4. it is a group b car with turbo and supercharger. because the motor was so small they could make it lighter ;]
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    Quote Originally Posted by a4mafia(Red) View Post
    it says you can only install these after the throttle body on turbo cars. umm that would mean inside the intake manifold? i would like to see how they do that.
    screw companies like this that off 100% satisfaction guarantees but in the fine print it says "15% restocking fee on all returns, buyer gets screwed on shipping both ways"... 60% of your money back is the same as 100% right? hey that doesnt matter, theres a chick in a bikini standing next to a nice car!
    Active Member One Ring petermca4's Avatar
    Aug 20 2007
    Melbourne, Australia
    FYI:
    Volkswagen Golf GT Specifications
    The CarAdvice team were at Mt Cotton driver training centre yesterday at the launch of the new Golf GT, so before we get our “first steer” article up and going, lets have a closer look at the technical details of the new Golf GT.
    <A class=imagelink title="2007 Volkswagen Golf GT" href="http://www.caradvice.com.au/wp-content/uploads/2007/05/2007volkswagengolfgtfront.jpg" target=_blank>
    The Volkswagen Golf GT is the first car in a production to employ a turbocharged & super charged FSI engine - the idea being that by super/turbo charging the engine, it will gain maximum power with minimum fuel consumption, but does the theory work?
    Yes! The compact 1.4 litre direct-injection engine develops 125 kW of power and has a maximum torque of 240 Nm in the range from 1750 to 4500 rpm thanks to the combination of an exhaust turbocharger with a mechanically driven supercharger. All of this power from a 1.4-liter engine? But at what cost?
    <A class=imagelink title="Golf GT Rear" href="http://www.caradvice.com.au/wp-content/uploads/2007/05/2007volkswagengolfgtrear.jpg" target=_blank>
    The 1.4-liter engine uses only 7.7 l /100 km for combined city and highway driving, not a bad feat for a 125kW engine!
    <A class=imagelink title="Golf GT Engine" href="http://www.caradvice.com.au/wp-content/uploads/2007/05/2007volkswagengolfgtengine2.jpg" target=_blank>
    The table below shows a comparison between the Golf GT twin-charged engine and the 2.0 FSI engine (both from VW)
    Golf GT 1.4 TSIGolf 2.0 FSISwept volume1390 cc1984 ccBore/stroke76.5/75.6 mm82.5/92.8 mmValves per cylinder44Compression10.0 : 111.5 : 1CompressorSupercharging Turbocharger-Boost pressure2.5 bar Power125 kW/170 PS at 6000 rpm110 kW/150 PS at 6000 rpmTorque240 Nm at 1750 - 4500 rpm200 Nm at 3500 rpm 0 - 100 km/h
    (0 - 62 mph)7.9 s*8.8 s*In-gear 80 - 120 km/h
    (50 to 74.5 mph)
    5th gear8.0s*9.0 s*Maximum speed220 km/h (136 mph)209 km/h (130 mph)Consumption7.71 / 100*8.01 / 100*CO2 emissions
    combined183 g/km*192 g/km** Manual gearbox You have to wonder though, with this many Volkswagen Golf variants flying around, how does one distinguish between them? Volkswagen have worked hard to differentiate all the different models, the new front section with its V-shaped radiator grille in the body colour is the exclusive preserve of the new Golf GT.
    Like the GTi, air inlet holes are integrated into the front bumper of the GT, but are more understated than in the GTI. There is an opening for the twin tailpipe in the rear apron. The GT is 15 millimetres lower than the standard level plus it also gets 17-inch wheels.
    <A class=imagelink title="Golf GT Dash" href="http://www.caradvice.com.au/wp-content/uploads/2007/05/2007volkswagengolfgtdash.jpg" target=_blank>
    If your wondering where all the power goes from the GT’s twin charged engine, and your thinking, is it DSG? Yes it is, there is a choice of six gears - manual or DSG. The car is driven through the front-wheels (same as the Golf GTi however the Golf R32 is AWD).
    Although in standard guise, the Golf GT comes in a manual, for those willing to pay a little bith more (and why wouldn’t you, the DSG is worth it) it will also be possible to combine this engine with the crisply shifting six-speed DSG transmission. Volkswagen are hoping to convince buyers to tick the DSG box, after all, this car was designed for DSG.
    Standard equipment on the Golf GT includes
    • electric windows,
    • electrically adjustable and heated outside mirrors,
    • central locking with radio remote control,
    • six airbags,
    • head restraints and threepoint seat belts for all five seats,
    • electromechanical power steering
    • ABS with Electronic Stabilisation Program (ESP) and traction control (ASR).
    • 17-inch alloy wheels in the “Classixs” design with 225/45 R17 tyres.
    • The 16-inch brakes (as in the Golf GTI) combined with Brake Assist
    1999 A4 1.8Tqm
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    "You know you have a bad idea when Ford guys are making fun of you."
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    if petermca4's post wasnt in weird units it might be a little better.
    wtf is 125kw?
    __________________
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    1.8t / gt35 / g60 / dyno run
    http://nl.youtube.com/watch?v=TxVvABL0Yng
    Jim
    I Do Werk.
    Aug 20 2007
    wtf is 125kw?
    lol... it's about 170hp
    1999 A4 1.8Tqm
    Veteran Member Four Rings Tifun's Avatar
    Jun 21 2007
    99.5 A4, 08 Mazda3
    Indianapolis Indiana
    The new PVW has a MK4 GTI twin charged. I onl caught part of the article but its a pretty good read with some good pics.
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    sweet! thank you for all this info you guys
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    I know this has been done to a B5 before. I remember an article in Maxpower(pre-Eurotuner) back in like 2000 about a dude in Canada that did it. It was the issue that had the Beetle with the TT conversion done on the outside(BeeTTle). I know I have it somewhere, I'll try and find it.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Nov 18 2008
    Los Angeles, CA!!
    I differ, it makes you look like a loud asshole.
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Quote Originally Posted by ghosta4 View Post
    ^^^that was unnecessary
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    ^^X2
    Village Idiot!!!
    (\__/)
    (")_(")
    Senior Member Three Rings a4mafia's Avatar
    Aug 22 2008
    B5 A4 Avant. Ford F250 PSD. Mazda3. Raptor 700r.
    Cincinnati
    x3 (got your back j )
    Veteran Member Four Rings terraflata's Avatar
    Sep 14 2008
    '97 Audi 1.8TQM '97 Acura Integra 2002 Dodge Durango
    Chambly, Quebec, Canada
    A concept I liked a lot better than "Twin-Charging" or Compound Charging" was the VCR (Variable Compression Ratio) Engine from SAAB. They were able to adjust compression ratio seamlessly. They managed to make a 1.5 liter inline 5 that made 225hp/225tq using a supercharger. Very nice technology, they just never produced the engine.
    Mar 09 2004
    nw michigan.
    I think Bahn Brenner did a red Corrado with a 1.8t minus the t and plus a Lysholm.
    Jim
    I Do Werk.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    That is the car he entered into the 1.8t Challenge. When I saw him at this years Eurotuner GP I asked if he still races that car and he said no.
    Here is a video of it at the 1.8t challenge
    BTW the reason no one has added a super charger to the 1.8t with a turbo on it still is because there is no room to put a SC if the turbo is still there. The SC would help with low end tq, but would then become a restriction for the turbo at high rpms. Plus I dont see why you would want to push hot air thru a SC and there wouldn't be enough space to put 2 coolers. Odd thing is that you never see a twin charged car making big hp or running fast times at the track. I bet those setups get some really shitty gas milage vs just a turbo.
    Nov 09 2007
    Si,NY
    Some shitty driving there
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Quote Originally Posted by bob12312357 View Post
    http://www.audiforums.com/forum/showthread.php?t=82960
    __________________
    Registered Member Three Rings kovalevandrew's Avatar
    Oct 19 2008
    South Africa
    That was some gay ass driving.
    HAHAHAHAHHAAHHAHAHAHAHAHAHAHA!
    I read through that lot, and fuck them all.
    01A4T is a stupid <NO NO NO NO!!!!! You did so not just edit my shit!>. Running from the cops, dude 10 points in my book. Done it a few time already, and i'm sure i'll do it again... As long as the wife isn't in the car... Man she was super pissed off the last time i did that shit.
    Jul 07 2004
    socal
    LOL, pretty sure that was a very experianced driver running that car at the 1.8t challenge. Fact is that car was out on the track twice during that event with 2 different drivers.
    Maybe the driving wasn't bad, just the fact that you need glasses.
    Oct 19 2008
    South Africa
    Quote Originally Posted by kovalevandrew View Post
    Damnit, i just got a lecture... Wife is reading my posts...
    Apparently i was being irresponsible... Or something like that... Me... Neeeeeeeever!
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    __________________
    Oct 19 2008
    South Africa
    They be hating on bob12312357. Not cool...
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    too much reading...
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    X2!
