Results 1 to 19 of 19
    Oct 16 2008
    South Florida - Ft Lauderdale
    Lightbulb Headlight LED Project
    Hi Guys,
    If you surf on the A4 B7 Forum, You will see that I just finished a LED project that look like this:
    I would like now to try on a B6 headlight. To do so, I am looking for a Donor who has a set of headlights lying around. I will pay for the shipping back and forth and the Donor will have the LED upgrade at discounted price. Of course, there is no certainty that I will be able to adapt the mod. If it's the case, I will return the headlight but they will still, be usable.
    Please PM me if interested and if you have a set
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    Re: Headlight LED Project
    makes me wish i had a spare set laying around....
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    I do have two spare sets, one is e-code, other DOT, both have broken tabs on one unit (either left or right). I keep them for experiments like that. Wasn't similar mod done in A3 forum?
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    If you werent so far away I would send you my ecodes.
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    Veteran Member Three Rings ridelikeme's Avatar
    Jun 15 2005
    B6 A4 , Avalanche LT,
    Calgary
    definately done already.. search for my post on it. the lights have been modified since then, removed the amber running light too. ill post new pics when my winter rims get here
    Jun 15 2005
    Calgary
    Veteran Member Three Rings ThatGuyAlex's Avatar
    Jan 24 2008
    NorCal BayArea
    ^^^ Not to be mean but his B7 ones look better built and brighter then those B6 ones.
    Fastest slow car down mountain roads you ever saw!
    Jun 15 2005
    Calgary
    haha they are that bright at night. Those pics were right after the install with a 12volt to make sure they worked before I wired them up I will try to get some pics tomorrow. I do completely agree that the shape of the b7 light is much nicer. But they are the same LEDs from the same source
    Registered Member Two Rings Jim@STaSIS's Avatar
    Sep 22 2008
    sonoma, ca
    those look great! nicely done.
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Good job.
    But I got something in the works, that's going to top you.
    Stay Tuned.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Established Member Two Rings ABsKiLLz's Avatar
    Jul 03 2008
    2002 Audi A4 1.8T
    Bronx, Ny
    somebody give this man some headlights. Looks like he might do a better job than those ridelikeme. I personally dont like that quality.Would love to send u some if i had a spare set. Maybe if u were local I would of done it to cut shipping time being as I need my car to get to work.
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    i think the led's need more space in between them so that they look more like the newer audi's headlights and you can see them individually better, instead of just looking like a solid beam of light across the bottom.
    Like the R8 headlights:
    Now that would be sick.
    - Justin -
    Veteran Member Four Rings KareemA4's Avatar
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    Hi Guys,
    im still looking for my old headlights
    once i find them ill meet up with you and give them to you.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    This looks VERY nice
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Quote Originally Posted by A4 Moda View Post
    Good job.
    Stay Tuned.
    Me too. Canibalized two sets and have a dual side-by-side projector lens high/low (got rid of that huge high beam housing) ecode that will be overlayed carbon fiber interior instead of painted, and the LED pattern closely matching the B8 A4. The LED pattern that curves down around the projector and then sweeps back up to flow in to the line that is formed where the hood and fender meet (see pic in post below). Not like the S5, which goes straight across before curving up. Had folks in the B8 forums sending me pics for a while now so I can match it as closely as possible within the constraints of how the dual projectors sit.
    Then I'm CF overlaying my splitter and grilles so the whole front end matches. If greg still sells them, I'm going to get the S4 exhaust surround in CF also to tie it all together.
    Right now I'm toying with a moldable frosted lens cover over the LED strip like the B8 has so you don't really notice the individual LED bulbs when they are off.
    The preliminary steps are completed and everything functions, and I'm just waiting for my CF 2X2 twill weave cloth to show up. Should have them done about mid-December. Mine also have a way to change the LED's if any burn out.
    I don't care if anyone copies these ideas; if you've got the skills to pull it off, more power to ya.
    My 2004.5 APR Stage 3+ is SOLD
    Feb 28 2006
    Pittsburgh-Philly
    Quote Originally Posted by SeatownB6 View Post
    The B8's are closer together. I'm trying to match the B8, not the R8 or S5. Like THIS:
    Veteran Member Three Rings jojoampt's Avatar
    Jan 19 2008
    02' A4 Avant, 1.8T QM, 08' S-Line A3 MT
    Humboldt County
    Jun 11 2005
    Excellent. Can't wait to see it.
    Serviceability is definitely a huge concern. Leds can't just be shoved in headlight housing in hopes that they will stay lit long enough until one moves onto the next whip.
    Also, another note about the frosted lens. I've been looking into that a great deal, and I can't seem to find anything remotely good looking to accomplish that. because if you just use regular old frosted glass spray paint, it's going to cut out light rather than enhance it, which OEM cheese grating frosted plastic does.
    So here's are 2 suggestions that may help you jog some ideas or improve current ones.
    1. plastic is rather pliable at certain, or above rather, certain temperatures. I had the idea of taking a factory, any old factory "clear bumper lens" from the 90s, (yeah 80s and 90s that was the thing back then. Yeah I'm old, deal with it), they made a lot of these bumper lens covers.
    I thought of using these for two reasons.
    1. they are very thin. That's exactly what I would want because space is very limited, and thin also means the plastic is easily pliable.
    2. The lens already has reflexive particles embedded in the material, and the grooves/gratings in the lens diffuse light nicely without sacrificing intensity .
    Similar to something like that. It would have to be clear of course. or do they? Put it in the oven, or use a torch to heat, mold, heat, mold, heat, mold, etc. until you get the shape you want. Of course, for our applications, the little frosted reflectors/ "led projectors" would have to be more long than they would be fat. So some cutting would be involved.
    Though #1 might be a longshot, these items already have the factory reflectors inside the frosted lens, so it will actually project and diffuse light making the light brighter and more visible. Whereas throwing a coat of frosted pain on clear plastic/glass will actually reduce the light output altogether. Ask me how I know.
    If you want to look into #1, I used to sell a lot of these bumper lenses back in the day. I still have a small stockpile of them. Just let me know and I'll go dig it up for you.
    #2 Okay, this may be taboo or "ghetto fabulous", but DEAL WITH IT. Anyway, back on point. Years ago when everybody was wondering how in the name of Gray Davis' ridiculous government benefits did BMW get those COOL demonoid seductive ANGEL EYES! Well Some people got tired of BMW loafers strutting about like they were made of some special cut of God's Cheese that nobody else could touch.
    So, people got really creative in transforming everyday items at home into those very ANGEL EYES made to be retrofitted into almost any headlamp housing (size permitting).
    here is the DIY LINK
    You could use an angel eye rod to made the reflector/projector for your led project.
    1. the rod is definitely thin/small enough to fit into the housing no problem
    2. it is uniform in shape, so it' might turn out looking better than idea #1.
    3. also very pliable
    4. I think best of all, you can fashion your own grooves in it to create a look most conducive to light dispersion and/or reflection for the LEDs. And since, you were looking at the B8 light, which during the daytime is blinding already, this rod might be just the thing. You can create the spacing as close or as far apart as you like, then chamfer the little slits in there in reference to the location of your LEDs.
    But of course instead of molding into a circle, you would mold it into
    the contours of the headlamp.
    Anyway, hope this gives you some ideas about your project. If you have questions, don't hesitate.
    More power to you.
    Quote Originally Posted by rxrep View Post
    2003 1.8T
    Jun 15 2005
    Calgary
    i will have some pics and possibly a video of mine up tonight, or tomorrow morning. just to prove that i did quality work and it looks damn good at night.. i only wish i had city lights to light up the entire housing like on buddies B7, cause lets face it.. that looks deadly
