Page 1 of 3 123 LastLast
Results 1 to 40 of 82
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    catch cans...school me please.
    ok.
    i see a but of info about these and i was looking for some more info.
    i see the benefits as being cleaning up the engine bay a little by deleting the pcv junk, and ensuring that no hot oil is put back in the motor or the intercooler.
    1st, what the hell is the pcv system, and is there any downside to removing it?
    2nd, i see 034 has 2 units, 1 with the filter sold seperatly. any more info on thses units or others?
    97 A4 2.0TQM
    Rochester, NY
    Re: catch cans...school me please.
    Not going to get into details on how the PCV system works, but I'd suggest keeping it.
    Ideally, you'd have two catch cans.
    One would be placed between the vacuum line that goes from the PCV valve to the bottom of the intake manifold (would need small hose fittings on it, since it's a small vacuum hose)
    The second would be routed off of the hard line, before the pancake valve on your turbo inlet tube.
    That way you'd still have the benefits of a PCV system, without the possibility of oil being sucked into your engine.
    in other words, your pcv system would stay exactly the same as it is now but you'd add two catch cans to collect any oil. That way you'll still pull a vacuum on the crankcase and ventilate it, without having to suck oil into your motor.
    I'd suggest looking into saikou michi catch cans, they are some of the very few on the market with internal baffling...
    http://www.saikoumichi.com/
    You'd want their stage 1 catch can for the vaccum line under the intake manifold, and their 951 catch can for the bigger line that goes into the pancake valve.
    fwiw, i would never run my car w/o a PCV system again...I did it for a while.
    May 07 2007
    what were the problems you ran into?
    and is there no way to run only 1 catch can off the hard line (thats where most are, correct?) without deleting the pcv system?
    May 07 2007
    just read up a bit...the valve coming off the TIP, is that eliminated with the catch can? as well as the hard line going into it?
    if this is the case, where is the inlet to the catch can coming from; the TIP or the motor? and what happens to the open end?
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    There is tons of info about this on here. Search and you can probably answer your questions.
    I have one catch can running the line from valve cover and line from crankcase into a "T" and then into a Summit Racing catch can. Seems to work perfect. And there is some nasty stuff that goes into that catch can.
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    May 07 2007
    f15046, any pics?
    i searched but all i could really find was BT/BAT build threads. im specifically looking for info on these
    Oct 30 2007
    Griffin, GA
    I'll try to take some pics tonight or tomorrow. It is really simple. I used heater hose, and I had to get the adapter that 034 sells. It plugs into the block. The catch can from Summit is around $30-$35 bucks.
    ** 2001 A4 TQM
    May 07 2007
    so does your setup do what pac describes but with only 1 can, or did you delete the pcv?
    Oct 30 2007
    Griffin, GA
    I deleted the PCV system all together. Catch can only, no vacuum source is attached to my catch can.
    ** 2001 A4 TQM
    May 07 2007
    ok. i need to learn more about this because im not sure where the catch can is located exactly, thats why i ask for pics, haha.
    May 07 2007
    by the way im doing this on an AEB, any considerations or issues?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Vented can for me. Just make sure to mount the can as high as possible.
    Picture of my block breather setup using the 034 adapter.
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    i lol'd at that site...
    "SAIKOU MICHI : USA MADE FOR YOU!"
    looks like a decent inexpensive product none the less. i still need to install a catch can as well.
    Quote Originally Posted by f15046
    wouldnt the T connection defeat the purpose of having the can inline with the pcv system? the oil would have a 50/50 chance of going in either direction of the T and wouldnt be forced to go thru the can.
    il probably delete the whole system altogether into a vented can just so theres one less thing to worry about leaking air.
    Jul 07 2004
    socal
    Quote Originally Posted by ghost6303 View Post
    He doesn't run it inline, the 2 spots end at the vented catch can. I think you missed this post of his
    Quote Originally Posted by f15046 View Post
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    what are the benefits to mounting this higher ?
    its air.. not water ?
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Jul 07 2004
    socal
    Quote Originally Posted by pacman View Post
    Actually there is this thing called "Oil" in your crank case and is where you want it to stay. Plus any oil or oil vapor that doesn't make it all the way to the catch can ends up going back to the crank case once there is no pressure in the line.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    If it's vented you need to mount it higher. That way it doesn't spill. You DO NOT want to be "that guy" that spills fluids on the track.
    If it's recirc'd into the exhaust or into the intake, you don't need to mount it high. A check valve wouldn't be a bad idea for those who like corners though.
    I don't honestly know if you would need it, but that block breather isn't that high up in the block.
    Jul 07 2004
    socal
    Well adding a line to the valve cover really helps get more pressure out and with that you still want to keep the catch can inlets at that level or higher. Doing both is really needed for those that really want to push high hp and run 8k+ rpms.
    Apr 14 2008
    a4 avant
    marlboro
    sorry poor pic...but its just like mikes ran from that spot on the block straight to my can no pcv system i believe
    -vrt-
    Jul 07 2004
    socal
    You might want to put a shield on the filter to keep oil from getting all over the turbo/dp just in case oil gets sprayed out. I would just tack it right to the can on that side.
    May 07 2007
    would it be better to vent the can or have it recirc. back to the intake or mani? im thinking venting is the easier route...
    Jul 07 2004
    socal
    Quote Originally Posted by unorthodoxa4 View Post
    Depends on what your trying to do. Better to vent for power and better to recirc for emission. You can also route it back into the exhaust if you want a vacuum source but you want to do that after the 02 sensor.
    Yes venting is much easier and a much cleaner look. But make sure you mount the can in a spot that is not near your cabin filter if you like using the fresh air feature of your a/c or heat.
    May 07 2007
    emissions wont matter, i cant pass as it is.
    for those with a vented setup, is under the coolant resi. the best bet?
    Jul 07 2004
    socal
    That is where I used to have my old one, I mounted it right to the ABS bracket. My new one is mounted in the stock battery location.
    May 07 2007
    figured i would bump this vs. starting a new thread.
    anybody using this setup? if so, is there enough room between the inlet and the outlet to mount a small filter (for venting) on the outlet port? they look pretty close together, so i want to make sure i can get the filter on there as well as the inlet line.
    thanks!
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    i have a wawa bottle with vents cut in as my catch can on my b5 lol
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Veteran Member Four Rings wesleyfbm's Avatar
    Aug 25 2008
    the 01 a4 tttt and my BMXer
    rhode island
    I have the 42 Draft Designs catch can. Line coming in from breather tube off valve cover and recirculated to where the pancake valve used to be.
    Where I mounter mine:
    May 07 2007
    hmmm, i thought it was better to have it vent in order to avoid the oil going back into the TIP.
    Veteran Member Three Rings BlkBullitt's Avatar
    Feb 06 2009
    2007 Q7
    Cleveland, OH
    In order for a crank case venting system to work most effectively there needs to be some sort of vacuum source connected to the catch can to help draw out pressure. So you could just stick a filter on your catch can and vent it into the engine bay, but it won't be as effective as if it did have a vacuum source (not to mention you may experience the smell of oil inside your car from venting the system). Hooking it up to the TIP fixes the problems with venting the system, however, you do still run the risk of oil potentially entering the TIP. The best solution, but not the easiest or most cost effective one, would be to have a check valve welded into your DP and run the catch can to it. The exhaust would create a vacuum source, the check valve would prevent the exhaust from entering the catch can system, and any oil that gets past the catch can system would be burnt off in the exhaust.
    2002 Audi S4 Brilliant Black Avant 6MT[/b]
    B5 A4 / S4 Headlight and HID Thread | B5 A4 / S4 Center Console Thread
    Aug 25 2008
    rhode island
    The oil is trapped at bottom of catch can while fumes recirculate to the TIP.
    May 07 2007
    I have read that. so weld a bung onto the downpipe (post cat anywhere would be fine i guess) and run the outlet of the catch can to it, with a check valve emptying to the exhaust?
    hmmmm, that may be do-able.
    Established Member Two Rings goonies's Avatar
    Jun 28 2008
    oz
    not a bung..this..http://vibrantperformance.com/catalo...oducts_id=1243
    honestly this is a very nice piece but you can make something that performs just as well easily. make sure you position the cut properly as one way will force pressure in and the other actually creates a vacuum using different air pressures/velocities.
    Nov 21 2006
    san francisco, ca
    Here is my setup. We put a nipple on the valve cover and tapped the oil pan for a drain. We used the turbo inlet hose to provide vacuum. It came out like so:
    --dillon
    1998.5 A4 2.0TQM ADR/058, Custom ME5 tune by 034, ABA 92.8 stroke forged crank, Scat rods, JE Pistons (83mm/8.5:1), Schrick cams, Supertech springs and retainers, inconel exhaust valves (+1mm), Spa T3 mani with a Precision 5557E-B, 034 3inch exhaust, etc, etc, etc. 034 featured user
    2012 S4 Prestige, Titanium, Monsoon gray metallic, DSG. 034 ECU and TCU tunes and other bits.
    May 07 2007
    what do you guys think about this? i could vent it and drain it weekly/bi-weekly as needed too.
    http://www.jegs.com/i/JEGS/555/51137/10002/-1
    i have to assume that those who are venting need to top up their oil semi-regularly as well?
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    you dont need to clean out the catch can that often, some do it every oil change, others wait longer etc..
    that can looks good too, comes with various fittings etc.
    i still need to get around to finding a drain valve for mine bc all it was is a hex shaped stud to remove.
    btw, if you change your mind & want to weld a check valve into your exhaust, LMK bc i have one around somwhere
    Registered User Four Rings ModBargains.com's Avatar
    Mar 09 2010
    La Habra/CA/USA
    I see that you're interested in the BSH Competition OCC and I'll do my best to help you out! This kit is completely bolt on and is designed with one goal in mind - Keep your engine clean and healthy!
    The purpose of a catch can system is to collect/vent the blow by vapors inherent as part of the combustion process. The factory setup sucks these oily vapors directly back into the engine exposing them to everything in their path.
    In the short term getting these vapors out of the combustion path reduces knock retard by not allowing oil vapor to mix with the air fuel mixture. In addition the more free flowing lines allow the engine to rev easily giving a more responsive feel to the engine as a whole.
    Over the long haul these untended to vapors will build up over the intake valves leading to a host of running issues and an expensive repair bill to fix. With a catch can installed you will save yourself from dealing with this hassle.
    Feel free to shoot me over an email at [email protected] if you have any questions at all!
    Alan Wei
    www.ModBargains.com
    714-582-3330 x 8006
    Nov 06 2006
    garage ornaments
    southeastern pa
    honestly my ebay unit has been working great for me, but im looking to upgrade to a dual inlet so i can draw at the crank case, and the valve cover..
    -Nic
    My Car
    May 07 2007
    actually Nic thats not a bad idea...but where would the oil at the intake come from?
    Nov 06 2006
    garage ornaments
    southeastern pa
    huh ?
    -Nic
    My Car
    May 07 2007
    wow for some reason i read intake manifold, lol.
    Quote Originally Posted by ModBargains.com View Post
    for $234? not likely, lol.
