Results 1 to 10 of 10
    Jul 28 2007
    Melbourne, FL
    new boost gauge buzzing
    Hey just installed my new vmr integrated vent mount boost gauge, along with the included inline airfilter. It buzzes at full boost, I was wondering if there was anything else I could do to eliminate the noise.
    THanks
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Re: new boost gauge buzzing
    Not sure if the VMR gauge comes with a flow restrictor, but if not...
    http://www.ecstuning.com/stage/edpd/...productID=2989
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Jul 28 2007
    Melbourne, FL
    hm so its rapid flow of gas that causes the buzz? Mine just came with a regular t-fitting (at least i think). Maybe i'll try one of those, anyone else have good experiences with them?
    Thanks a lot!
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    You need some anti buzz restrictors.
    http://www.podi.ca/Accessories.aspx
    Veteran Member Four Rings VAG_4ever's Avatar
    May 27 2008
    IL
    where did you put your inline filter? my awe one buzzed as well, i now have 2 inline filters, one by the t-fitting in the engine bay, the other a few inches from the acutal gauge tucked under the vent.
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    Quote Originally Posted by [email protected] View Post
    only needed one to stop it but it comes with two, great service as well
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Veteran Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    Macan Turbo, Cayenne Diesel, Audi Jr Quattro
    West Coast of Michigan
    I had an adjustable in-line restrictor (had a little dial). Kept adjusting until just enough flow to read boost, but not enough to cause "buzz".
    FS: Audi TT 225Q Roadster
    Established Member Two Rings dannyace's Avatar
    Aug 27 2009
    2006 Audi A3 Sportback DSG 2.0T FSI BPY
    Baltimore
    Quote Originally Posted by OneBadAudi View Post
    I just installed the Podi Stewart Warner gauge with the anti-buzz fitting, 14" after the T. Where did you install yours? Mine still buzzes at full boost.
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Quote Originally Posted by dannyace View Post
    You should install the first restrictor 8-10" from the back of the gauge, if the gauge still buzzes then you install the second one 8-10" from the t-fitting at the manifold.
    Hope that helps
    Jun 14 2005
    Anaheim, CA
    wow back from the dead! lol, anyway if the OP is still having the issue, please shoot me a PM
    Brandon @ VMR Wheels
