Results 1 to 11 of 11
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Part Number Needed:
    Looking for the PN for the rubber grommet that is to the right of the brake booster grommet. In the picture below, there is a large hose going through it but in stock form, there is no hole.
    Lost it last weekend doing my boost gauge/turbo timer install.
    Pic Reference:
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Re: Part Number Needed:
    ill look when i get home if no one posts its up, nice tensioner btw :)
    Active Member One Ring brmin88's Avatar
    May 02 2008
    2000 S4
    Kingsport, TN
    I need one as well, mine dry-rotted
    Silver 2000 S4 6MT
    Jun 01 2008
    Apopka, FL
    Good luck with that.. it seems like you should be able to purchase it seperatly, however I remember when I went to the dealer for a couple grommets I got a nice surprise that it's not sold seperatly any longer, and only with the entire electrical harness it was attached to. The ones I were looking for even had part numbers on them.
    I'd give you the one off my junk car.. but it's a 1.8T so It has a hole in it for the BB line(so i'd probaly have to make a cut in the grommet to get it off), lmk if you still want it.
    Feb 14 2004
    S Ã C, CÃ*
    only one i can come up with is 8d0611743 with no letter at the end. All the others i see are for the brake booster vac line grommet.
    Jan 29 2007
    08 S4 00 S4
    MD
    If it's the tear drop shaped one, I believe that's it.
    08 S4- Stock SOLD
    Sep 19 2008
    Toronto, Canada
    Yes, the tear-drop shaped one.
    I suppose I'll try with the PN listed and get some luck.
    Anyone else? Is there an actual part number listed right on the grommet?
    May 02 2008
    2000 S4
    Kingsport, TN
    That PN pulls up a grommet on genuine audi parts, its just over $3 so I will be getting it along with a few other trim pieces which have seen better days. Thanks infinkc for looking up that PN
    Silver 2000 S4 6MT
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Nice RS4 Y pipe
    l gotta-- l gotta get
    a form from a scientist.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by CONTROL ONE View Post
    Nope
    08 S4- Stock SOLD
    Feb 14 2004
    S Ã C, CÃ*
    Quote Originally Posted by brmin88 View Post
    keep us updated if it is the correct part, i had to look at a older european model line to find that part number, the USA ETKA says part not found. I know the grommet that has the brake vac hose has the same base part number but with like a "B" at the end, its on the grommet itself.
    number 14.
