Results 1 to 4 of 4
    Jul 21 2008
    Phoenix
    Timing chain tensioners?
    My car is about to go out of it's 100k warranty.
    How would someone know if the timing chain tensioners were going bad?
    I have a B6 S4.
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    Re: Timing chain tensioners?
    Quote Originally Posted by tymeks View Post
    I have a B6 S4.
    Misfires and running really rough. Dealer wont replace them just for the early startup rattle.
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Veteran Member Three Rings Jdubya's Avatar
    Apr 05 2006
    05 S4
    Dayton Ohio
    Unless they are COMPLETELY gone I don't see how misfires would be a result of bad tensioners. The engine would have to jump time. You would have bigger worries if that were the case.
    Loud valvetrain noise would be a good indication. Plastic pieces in the oil pan would be another.
    FI DP | FI CB | JHM IM | JHM TUNE | JHM N20 | SB STAGE III/LWFW | PORSCHE BBK | BBS CH | KONI/H&R
    May 30 2007
    MA
    Quote Originally Posted by Jdubya View Post
    Slack in the chain could definitely cause it to jump thus throwing off the timing thus causing a misfire. Im almost 100% positive that the chain is not open to the oil pan below. Plastic pieces from the guides would be unnoticeable in the oil.
    I dont think their is a clear set indicator that your tensioners are going. We need someone to chime in here who has had to replace this part.
    2014 R8 V10 - Gated
