Page 1 of 3 123 LastLast
Results 1 to 40 of 95
    Veteran Member Three Rings 2BblkAudis's Avatar
    Feb 15 2007
    San Mateo, CA
    Aftermarket Bose Front Door Speaker Replacement
    Unfortunately both my front bose speakers blew out, and I had a hard time finding a replacement due to the 2 ohm bose amplifier. Fortunately I was able to find a 4" Infinity reference series speaker (Model 4022i). I picked them up from BestBuy for about $89.00.
    Install:
    I was able to remove the bose speakers from the mounting ring and still utilize the stock mount and rubber surround. Three of the speakers mounting tabs need to be cut shorter and you need to use some self tapping screws. One of the original original screw points are used and the other three locations are screwed down with the self tapping screws. Make sure to center the speaker so the rubber surround can be placed onto the mount correctly. With some
    Once the speaker is mounted mark where the screw heads are, and then trim the rubber surround so it can sit flush.
    Mount the speaker onto the door and use the stock wiring. ***Make sure to cut the wires that goto the stock tweeter. I cut the wire just above the female clip. The goal is to just have a positive and negative wire connected to the new speaker***
    Unfortunately I was rushing to get this installed before it got to dark so I was not able to take any pictures.
    Overall the speakers sound great and work perfectly with the stock Bose system.
    Last edited by 2BblkAudis; 11-24-2008 at 10:03 PM. Reason: corrected trip to trim!
    Veteran Member Three Rings BlueturboS4's Avatar
    Feb 21 2006
    2010 s4, 2001 S4, 2002 dakota
    Re: Aftermarket Bose Front Door Speaker Replacement
    nice find, i need to try this. Would you say the sound as good as stock?
    Feb 15 2007
    San Mateo, CA
    The sound is much better than stock. I'm more into clarity rather than bass, however it's a good balance of both. Overall I'm very satisfied. The speaker also has a 3 db boost, however I kept it at the 0 db setting.
    Veteran Member Four Rings will175's Avatar
    Apr 25 2007
    Las Vegas..Hawaii..Nor Cal
    I think mine might be on its way out. Nice find. How is the ecu treating you?
    Train Hard, Go Hard, But always be Humble.
    Feb 15 2007
    San Mateo, CA
    I got a new n75 and things seem to be o.k. now! I still get throttle cut here and there, but now my drivers side turbo is leaking oil, so K04's will come next year.
    Jul 22 2008
    Dallas, TX
    Nice work, I bought said infinity speakers and then bitched out and sourced some BOSE ones from eBay. That being said if anyone is looking to buy some I can't return them because I waited to long, so pm if interested.
    Jun 14 2007
    2000 S4
    Connecticut
    dam, I have to do that, thanks for the review. My driver door lower speaker is shot and you can only hear it on certain frequencies like when its talk radio you can really hear a buzz, but some songs you cant hear it at all. weird... thanks for the heads up
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Mike, one of these days. We should run our cars. Pump VS Pump.
    l gotta-- l gotta get
    a form from a scientist.
    Jan 12 2008
    WV
    why did you cut the tweeter wires?
    Veteran Member Three Rings nateS4's Avatar
    Apr 25 2008
    01.5 Nogaro S4 6spd, 02 GSXR, MkIII TDI
    Baltimore
    That's how my passenger side is, it's distorted on mid ranges on certain songs.
    2001.5 S4 Nogaro Stage III
    Test Pipes|AWE Twin1|Forge Hybrid BOV/BPV|JHM MBC|VAST Tuned|FrankenTurbos|034 Mounts|Hotchkis S-bars|RS4 Grille/Knob|50w HIDs|Vogland/Bilstien|JHM SS
    02 Suzuki GSXR Telefonica Movistar
    88 Bimmer E30 Vert
    98 Jetta TDI
    90 Corrado G60 Sold!
    92 Audi 100 Sold!
    http://photobucket.com/nateS4
    Veteran Member Three Rings NOVAS4's Avatar
    Sep 02 2007
    2003 Audi RS6
    Woodbridge, Virginia
    damn no pictures FTL!!! .. i need to do this and have no experience or any clue what im doing haha
    Current: 2003 Audi RS6
    Current: 2008 Acura RDX Tech (daily driver)
    Previous: 2013 Hyundai Genesis Coupe 3.8, 2006 Acura TSX, 2008.5 Mazdaspeed3, 2000 S4 Sedan 6sp stage3-, 2004 Subraru WRX
    Feb 15 2007
    San Mateo, CA
    The infinity speakers are coaxial meaning that it's a woofer and tweeter combination. If you don't cut the factory tweeter out you'll be running two tweeters in the door. It will also be running in parallel/series (don't remember which one it is) but it'll mess up the impedance.
    Aug 08 2008
    BC
    Leaving the factory tweeter in will mean you have two tweeters per door, but whether or not to leave it in should be a matter of personal opinion.
    It shouldn't create a impedance problem because it will only create a impedance drop at those upper frequencies, and a tweeter takes so much less power to create the same volume output as a woofer. This means it won't pull too much from the amp.
    We installed some Alpine Type-S coax speakers in a newer Jetta with the factory tweeters, and we found that it sounded better with the factory tweeters connected. So again, it'd be a matter of preference.
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    any further attempts with this? i personally would prefer to keep the factory tweeter as well... the idea of sound projecting at just my legs isn't quite audio-listic ... yeah i made that word up
    Lurker
    Sep 03 2007
    Wichita, KS
    I have the infinity reference 4022i speakers and I left my factory tweeters. I like the sound and I have cranked it up many times without any problems. The hardest part is making a round speaker fit into a triangular housing, but with some grinding and clipping it can be done. I even drilled pilot holes and reused the stock screws.
    Veteran Member Four Rings KompMan420's Avatar
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    I have a hunch that my wife is getting me a set of these for x-mas. I'll do my best to get pics and do a write up for everyone...
    SOLD - 2001.5 Audi S4 Twin Turbo ~ 450hp
    Mods - AWE/GIAC Stage 3 | AWE Intercoolers | STaSIS Coilovers | RS4 Clutch | 3" Borla Cat-Back | ASP DTS | JHM Solid Axles | "Piggie" downpipes | Neuspeed SS | AWE Pedals | IceLink for iPod | 710n DVs | M3 Spoiler | LM Reps 18x8.5 Satin Black w/red Time Attack
    www.NJSRealty.com
    Senior Member Three Rings theboogieman1's Avatar
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Quote Originally Posted by jerodmetcalf View Post
    I just installed last night with tweeters still in and I think it sounds fine. They are much clearer than the old speakers but that's probably due to the extra tweeters. Out of the box the +3db on the tweeter was selected so I put that down to normal for now thinking that might help. The install was pretty easy but I didn't do the best job on getting those things in there. I just trimmed the prongs down and used one screw thinking I'll go back later and secure them better. Even though they are pretty secure with only one screw cause the other prongs just barley fit in the plastic boarder so It's kinda pinching them in. Hope some of that makes sense. Anyone know what the rear door speakers are? I think I have one blown back there too. Are they the same?
    02' Black S4 6spd / JHM "Stage 3" / JHM "Solid" Shifter / VAST Stg. 3 Clutch and LW Flywheel / Vogtland GT's / 034 Track Density Motor Mounts/ AWE DTS / JHM FMIC / Hawk HPS Pads / H-sport sways / SSAutochrome TB Exhaust
    Jun 14 2007
    2000 S4
    Connecticut
    now before I click buy on these things... when you type in the car and it says it doesn't fit, is that just because there is the slight modification nessasary ? thanks for those who have reported back to us, I'm going to take care of this soon, it is so annoying!
    Feb 15 2007
    San Mateo, CA
    That would be correct. Our cars have a plastic mounting bracket. Usually if it's not a direct drop in fit, most company's will default it as "not fitting". When the weather clears up, I'll remove a door panel and snap some pictures of how I did it. I put four screws in to ensure a tight fit. One was in the actual original mounting location and the other three were my self made mounting holes. Just remember to mount mark, then drill a pilot hole. If you try to screw into the plastic without a pilot you will risk putting a nice hole in your new speakers from the drill slipping.
    Sep 02 2007
    2003 Audi RS6
    im trying to do this right now and was wondering what stock mount hole everyone used for the best fit thanks
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    take some pics
    B5 S4 AWE Stage 3 - sold
    Sep 02 2007
    2003 Audi RS6
    Quote Originally Posted by Rajan147 View Post
    take some pics
    yup i am no worries
    Nov 23 2007
    Columbus, OH
    Quote Originally Posted by NOVAS4 View Post
    yup i am no worries
    you da man
    Sep 02 2007
    2003 Audi RS6
    well got both of them in they sound great!
    well first off the door panels are much easier then i thought to get off. take off two top screws (on on each side).. then the one in the handle and then the two you reveal once you silde the plastic handle piece off. then lift up and out. and there is 3 orange/red screws holding in the stock mount.
    anyway onto the speakers
    a couple prehacked up pictures of speakers
    this is how i mounted the speaker on the stock mount.. 1 stock screw.. then made another hole for another screw and used lots f super glue on the others(i know its not pretty but so far its done its job)
    here it is mounted
    side notes: i left the stock tweeter in. i just used the stock wiring.. matched right up
    i think it sounds better then stock and i also pushed in the +3db button i think it sounds better with the extra bass but its personal preference.. took me about ~3 hours with everthing i took my time though im sure it very well could be a 2 hour job... any questions pm me or post it
    Nov 23 2007
    Columbus, OH
    So you used one stock hole, then just screwed in the others and just glued them in place?
    did you just simply have to swap the wires for the speaker or did you have to make any adjustments?
    Sep 02 2007
    2003 Audi RS6
    yeah i used one stock hole and one stock screw together and then i drilled another hole and used a small screw i had in the garage and the other two sides i cut off with plyers just so it would fit and i glue them down
    nope zero adjustments on the wiring (it was great)
    Veteran Member Three Rings KidGT's Avatar
    Oct 28 2008
    '00 S4
    The Mile High City
    Brilliant.
    Now if only someone would do the same for the rears.
    2001.5 Candy Blue Dipped S4 Avant
    Stage 2+, APR everything, Saved from idiots, and resurrected.
    2004 Touareg V8
    Parents never us it, so I kinda just stole it...
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    I only used the one stock hole and trimmed down the other facets of the speakers so I could fit it in the stock plastic housing and called it good. I would have drilled another hole so I could get more that one screw in but I'm really limited on time and place to work on my car. I also pressed down the button on the tweeter and all seems good on my end as well. No rattling or distortion in sound.
    Anyone know if it's the same speakers in the rear doors?
    Sep 02 2007
    2003 Audi RS6
    no the rear door is 3 1/2 inch
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    any good replacement speakers for those?
    Sep 02 2007
    2003 Audi RS6
    Quote Originally Posted by theboogieman1 View Post
    crutchfield.com which is where i get all my car audio stuff has these as will fit
    http://www.crutchfield.com/p_065S35/...35.html?tp=105
    http://www.crutchfield.com/p_136TR35...Xi.html?tp=105
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Do these not need to be 2 ohm like the fronts?
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Both of those are 4ohm speakers. Our Bose system runs on a 2ohm load which is why everyone is getting the Infinity Reference. They do make a 3 1/2"
    http://www.crutchfield.com/p_1083022...l?tp=105&avf=N
    www.NJSRealty.com
    Feb 27 2007
    Chicago
    I just ordered a front and rear set. thanks for the info guys!
    97 A4 2.7T OEM RS4 Widebody 6-speed
    01 S4 2.7T Imola Avant 6-speed (Sold)
    90 Coupe Quatrro 20v (Sold)
    Active Member One Ring 303S4's Avatar
    Dec 29 2008
    Denver
    Great advice. Installing these now in my garage!
    Jun 14 2007
    2000 S4
    Connecticut
    I just ordered a pair... I could of found them cheaper using shopping.com, on like ebay or some sites, but paying the extra bux with Crutchfield is so worth it. They know what they are talking about... He said you can use these, or the cappa/kappa (sp) from infinity since they are also 2OHM. The cappas are more expensive (120) but I went with the references since people have had great luck with them on here... He said you can also get references or the cappas for the rear as well (rear deck) they sell a bracket so you can use 6.5inch or 5.25 inch... Anyways, will install and let you know how I like it over the blown BOSE!
    Registered Member Two Rings
    Oct 28 2007
    PA
    Just ordered a set of the reference 4022i for $59 shipped from cartronixplus.com. They're supposed to be here Monday, I'll update when they get here.
    FS- Giac X Ecu $350shipped
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    so the equiv kappa is the 42.9. correct?
    Lurker
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Correct, for the front 4" in the Kappa series, you want the 42.9.
    www.NJSRealty.com
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    nice fiend
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
