So I went to remove my studs that bolt down the exhaust manifold to my turbo for the PES manifold on the T28 (square flanged with 4 studs). For some reason one of them seems to tighten up, then get all loose again (has been helicoil'd before FYI). If i just screw it in normal with my hand, it seems like its tightening up and that it keep on screwing in, but when i put the nut on the stud, it seems to get tight to the point of the nut, then it just gets loose again!!! Suggestions?
I will call 034 and ask them about some self threading studs of some sort, but any other help would be appreciated or where I can find some studs like this locally.
TIA!!!!
-Chris
