    Oct 13 2008
    Kansas
    Brake Light comeing on when starting out
    i have a question and i feel stupid asking this. I have a Audi a4 1999 2.8L manual and a lot of the time when I start out in 1st gear and start faster than usual (or for some reason that i dont no) the brake light comes on blinking and makes a beeping sound. I was just wondering what this is. Please dont tell me to look at my manual because i dont have one and dont wonna go get one.
    Thanks for all the help
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    Re: Brake Light comeing on when starting out
    Wheel speed sensor maybe? My front left Wheel speed sensor is faulty and the same thing happens. Check your codes to be sure.
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    Is your brake fluid low? Is the ABS light coming on also?
    Oct 13 2008
    Kansas
    no the ABS isnt on its not all the time also
    Dec 20 2007
    iowa
    What's not on all the time..... the brake indicator? Is the fluid low? The reason I ask this is because as you take off , stop, or turn the brake fluid sloshes around causing the level to change. If it is the indicator light that says brake in it (in red) it is most likely a low fluid level.
