Results 1 to 2 of 2
    Veteran Member Three Rings as4driver's Avatar
    Mar 28 2005
    2001 Audi s4, audi a4 avant
    Engine Rebuild???
    Hey guys im from the s4 forums. i think i am going to buy a 1999 A4 avant. The car has 157,000 miles and here is the recent maintenance:
    Many new parts added in the last couple months including Timing belt, T-Belt tensioner, Serpentine belt, water pump belt, Water pump, Thermostat, Brake pads, All the front control arms ($500 just in parts), tie rod ends, sway bar links, rear wheel bearing, Depo projection headlights, aftermarket head unit, N75 valve, New windshield and other parts.
    Im wondering what else i should be worried about or if i should rebuild the motor. This car will be my winter/ commuter car. My question is: How much would it cost to rebuild the motor with stock or close to stock parts? I dont think the car will ever see a big turbo but you never know. Maybe a ko4.
    Thanks
    Evan
    If i get it i will be sure to post pics.
    Here is a pic of my s4!!
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: Engine Rebuild???
    A German motor does not need a rebuild at that age if it runs and has good compression.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
