Results 1 to 10 of 10
    Buncha motorcycles
    Memphis, TN
    HID igniter woes (aftermarket)
    Ok, so i purchased this "OEM" HID kit from akinaboy. it uses OEM ballasts and pigtails with a aftermarket ignitor and some kind of deal to make the HID bulb fit.
    anyhow my problem is this. on one side, the igniter locks down (passenger side) and it secure. on the drivers side, it locks up and as im lowered it gets jarred around quite a bit on our memphis roads. It now blinks out constantly.
    i went to audi today and the OEM igniter is built together with the bulb and wont work on my non HID housings. I need a igniter basically that is small enough to twist and lock in place securely. Anyhow had problems like this?
    i included a picture and i am horribly embarrassed to show it as i have jury rigged the the headlight more and more trying to prolong its life so please dont laugh..... too hard anyway. the purpose of the ball is to keep the igniter from unlocking itself but... it isnt working.
    and BTW, the C stands for close or lock and O for open.. its what the igniter has on it
    APR Stage 2/AWE Intake
    Veteran Member Four Rings FireWire's Avatar
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    Re: HID igniter woes (aftermarket)
    friend had a similar problem with his setup , all i remember is he packed the enclosure with tin foil. not joking... it held it in place really well and did a good job absorbing some of the vibrations/shock from harsh road conditions.
    Typ 8E 03 1.8t Quattro
    2006 600RR
    my photos
    Buncha motorcycles
    Memphis, TN
    shit, do they not sell some kind of igniter seperately that will fit? i dont have $1k for ecodes and new bulbs/igniters!
    Jul 30 2008
    08 Passat 2.0t
    Near Mountain Creek
    look at the D2S connector--- the grooves may be worn out or damaged which prevents it from being secured properly.
    Get yourself a new ballast (Hella gen 3 type with integrated ignitor). I bought cheap ebay ones before to replace the AL-ballast & separate ignitor with good results.
    08 Passat wagon 2.0T 6MT (APR Stage I, DriverGear-Eibach springs, Bilstein Sport, Euro smoked tails, intake, ATE Premium One rotors, Hawk HPS, Tyrolsport Caliper Guide Bushings, other stuff)
    Previous Cars:
    02 Golf TDI 5MT (Chipped, Bosio PP764 nozzles, VNT-17, Shine Racing suspension, S3 strut brace, WRD rear strut brace)
    88.5 Camry V6 5MT
    84 Corolla 3AT (the FWD version, hand-me-down)
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by UGwagen View Post
    yes, the connecters are worn on the igniter. do you have a link for what i need? dont forget my housings arent designed for HIDs so..
    Jul 30 2008
    08 Passat 2.0t
    Near Mountain Creek
    it depends on how much you want to spend.
    You can get a DDM kit instead if you want.
    Previous Cars:
    88.5 Camry V6 5MT
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Wait I"m not understanding the problem.
    The bulb is bouncing around in there because you can't secure it on your H7 housing?
    And, one of the connectors are worn?
    Why don't you send the worn one back to AkinaBoy? He should warranty his product.
    Ax far as securing it, I'm not seeing how you're securing the bulb in there. Are you using the factory wire pin?
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by A4 Moda View Post
    ive done a terrrible job at explaining this i know lemme try again.
    the igniter clips onto the bulb or rather you put it on the bulb and twist it to lock it on. the problem is that on the drivers side, you have to twist it UP to lock it in place (since there isnt enough room to lock it on either down or on the other side) so when i hit all these potholes it jars it loose causing the bulb to blink out. it has done that so much now the plastic where the connecter locks onto is worn so it blinks out a lot now.
    i need a smaller igniter that would give me enough room to clip it on and lock it either down or on the right side
    the bulb itself is secured by slightly modifying the OEM metal clip. my plastic golf ball is to keep the igniter from boucing down and disengaging
    Oct 16 2006
    Naperville
    Would it be something with the D2S to H7 adapter he includes in the kit? Just a suggestion, try putting the passenger side adapter over to the driver side ignitor and see if it fits on snug.
    Buncha motorcycles
    Memphis, TN
    it would fit a little more snugly but i need a long term solution! i cant afford ecodes right now. :( this stupid economy is killing me! im making less than last year and much higher up in the company! plus if GM goes under, enterprise is will be crippled
