as the title says, slowly but surely! i have a 98 AEB passat with a KO4, stock exhaust mani, 5 bar FPR, stock injectors , FMIC, baily DV, silicone hoses etc... previously i have been only boosting to around 15psi. i check N gapped the plugs, replaced the breather hose & a check valve but i haven't pressurized the system since i replaced the breather hose. I also got a flat in there and moved the actuator a lil too.
anyways i finally got to disconnecting the N75 from the WG. & WOW haha obvioulsy more boost but it came on way quick and my KO4 never sounded so good :) especially driving through enclosed roads where i can really hear it spool.
So i get home and put the N75 back on the WG & its raining now but i drove for a min and was only boosting to 15psi.
I gota look at the tubes on the N75 but is it bad? maybe my DV? i checked & did that pressure test and it seems to work but i think it could open more inside the dv, ill try to post pic and explain.
thanks in advance
